Datasheet NV6288 (Navitas Semiconductor) - 8
ManufacturerNavitas Semiconductor
DescriptionGaNSense Motor Drive IC in Half-Bridge Configuration
Pages / Page34 / 8 — NV6288. 7.7. Electrical Characteristics (3, cont.). Covered part numbers: …
NV6288. 7.7. Electrical Characteristics (3, cont.). Covered part numbers: NV6288-01, NV6288-02, NV6288-04. SYMBOL. PARAMETER. MIN
NV6288 7.7 Electrical Characteristics (3, cont.) Covered part numbers: NV6288-01, NV6288-02, NV6288-04 SYMBOL PARAMETER MIN
link to page 2 link to page 22 link to page 21 link to page 2 link to page 23
NV6288 7.7. Electrical Characteristics (3, cont.)
Typical conditions: V =400V, V =15V, F =1MHz, T =25ºC, I =6A (unless otherwise specified) DS CC SW AMB D
(See Table 1)
SYMBOL PARAMETER MIN TYP MAX UNITS CONDITIONS Internal Current Sense Characteristics (CS pin) (NV6288-01, NV6288-02)
Across full range of VCS CS Pin Voltage Range Capability 0.5 3.5 V operation V I INL=5V, VCS=1.65V, CS0 CS Output Current at ISW = 0A -15 0 15 uA IDS=0A, see Section 9.6.2 INL=5V, R Minimum I CS from CS to I DS for accurate uni- DS_MIN 70 mA controller GND only, see direction current sense Section 9.6.1 CS Output Current at I V I SW = +/-50% * INL=5 V, IDS=±7A, across CS50 ±1.188 ±1.25 ±1.3125 mA IDSMAX temp CS Pin Delay (from I di/dt = 10 A/us, across t DS to ICS, at 10% CSDLY 65 ns rated current) temp CS Pin Delay (from I di/dt = 10 A/us, across t DS to ICS, at 25% CSDLY 35 ns rated current) temp
Internal Current Sense Characteristics (CS pin) (NV6288-04)
CS Output Current at I V I SW = +/-50% * INL=5 V, IDS=7A, across CS50 1.188 1.25 1.3125 mA IDSMAX temp di/dt = 10 A/us, across CS Pin Delay (from I t DS to ICS, at 10% CSDLY 65 ns temp rated current) CS Pin Delay (from I di/dt = 10 A/us, across t DS to ICS, at 25% CSDLY 35 ns rated current) temp
Covered part numbers: NV6288-03
(See Table 1)
SYMBOL PARAMETER MIN TYP MAX UNITS CONDITIONS External Current Sense Characteristics (CS pin) (NV6288-03)
Across full range of VSNS Full Scale Input Voltage ±100 mV operation, R3=R4=392Ω see Section 9.7 Across full range of VCS CS Pin Voltage Range Capability 0.5 3.5 V operation V I INL=5V, VCS=1.65V, CS0 CS Output Current at ISW = 0A -15 0 15 uA IDS=0A V I INL=5V, VSNS=±50mV, CS50 CS Output Current ±1.231 ±1.25 ±1.269 mA R3=R4=392Ω di/dt=10 A/us, across CS Pin Delay (from I t DS to ICS, at 10% CSDLY 70 ns temp, R rated current) SNS=12.5mΩ, across temp di/dt=10 A/us, CS Pin Delay (from I t DS to ICS, at 25% CSDLY 32 ns R rated current) SNS=12.5mΩ, across temp
Final Datasheet 8 Rev Apr. 29, 2025
