Datasheet PBRC-B (Kyocera AVX)
| Manufacturer | Kyocera AVX |
| Description | Ceramic resonator 3.58 MHz 33 pF SMD |
| Pages / Page | 2 / 1 — PBRC -B, -D Series Chip Resonators. Built-in Capacitor MHz Band SMT … |
| File Format / Size | PDF / 133 Kb |
PBRC -B, -D Series Chip Resonators. Built-in Capacitor MHz Band SMT Resonators. ƒ : 2.00 to 36.00 MHz. FEATURES. HOW TO ORDER
PBRC -B, -D Series Chip Resonators Built-in Capacitor MHz Band SMT Resonators ƒ : 2.00 to 36.00 MHz O FEATURES HOW TO ORDER
1) Built-in load capacitor
PBRC - 4.00 B R
2) High reliability chip resonator in a ceramic case which can 1 2 3 4 5 be reflow soldered and washed 1 Type: (Piezo Bulk Resonator Chip) 3) Ultra-miniature size is suitable 2 Oscillation frequency (MHz) for compact equipment and high mounting density 3 Resonator type: 4) Rectangular shape allows B = With capacitor (2.00~20.00MHz) easy “pick and place” operation D = With capacitor (20.01~36.00MHz) 5) 2000 pcs. per reel 4 Packaging: 6) Sold in increments of 2000 pcs. R = Tape and reel
STRUCTURE
5 Frequency tolerance: Ceramic Case = ±0.5% (2.00~8.00MHz) Ceramic Element 07 = ±0.7% (8.01~20.00MHz) = ±0.5% (20.01~36.00MHz) Conductive Paste Terminations: Nickel Alumina Electrode Ceramic Substrate Barrier with Gold Flash
SPECIFICATIONS (PBRC- B/PBRC- D) Series Type B D Frequency Range
2.00 to 8.00 MHz 8.01 to 20.00 MHz 20.01~36
Load Capacitor
33 pF (typ.) 10 pF (typ.) 10 pF (±10)
Frequency Tolerance
±0.5% ±0.7% ±0.5%
Resonant Impedance
2.00-2.90MHz 200Ω max. 150 Ω Max. 150 Ω Max. 3.00-3.57MHz 100Ω max. 150 Ω Max. 150 Ω Max. 3.58-8.00MHz 30Ω max. 150 Ω Max. 150 Ω Max.
Temperature Characteristics (-20 to +80°C)
±0.3% ±0.1% ±0.3%
RECOMMENDED LAND STANDARD TEST CIRCUIT STANDARD TEST CIRCUIT PATTERN FOR PBRC- B/D 2.00 ~ 8.00 MHz 8.01 ~ 36.00 MHz
(PBRC- B) (PBRC- D) 2.5 2.5 VDD = 5.0V VDD = 5.0V (.098) (.098) 14 MC14069UB 14 MC74HC04 (MOTOROLA) (MOTOROLA) 1 2 3 4 7 1 2 3 4 7 4.0 (.157) GND GND OUT R OUT R 1.0MΩ 1.0MΩ 1.7 1.5 1.7 Resonator Resonator (.067) (.059) (.067) C1 C2 C1 C2 33pF 33pF 10pF 10pF Unit: mm (inch)
DIMENSIONS PAD CONNECTION
3-1.2 (reference) 6-R0.2 (.118-.047) (.236-R0.008) Oscillation Frequency Date Code
1 3
1 2 3 2.6 3.4 3.0 (.102) (.134) (.118) 2.5 2.5 7.4 (.098) (.098) 1, 3: Input, Output (no polarity) (.291) 1. Input
2
2: GND 7. 2 2. Ground *t=PBRC B Series: 2.0 max. (.283) 3. Output PBRC D Series: 1.6 max. *t Tolerances = ±0.3mm Note: Pads 1 and 3 are interchangeable. 0.6 (.024) Unit: mm (inch) 14
