Datasheet PRTC (Kyocera AVX)
ManufacturerKyocera AVX
DescriptionMHz Band Ceramic Resonators (SMD)
Pages / Page7 / 1 — MHz Band Ceramic Resonators (SMD). PRTC Series. How to Order. Features. …
File Format / SizePDF / 673 Kb
MHz Band Ceramic Resonators (SMD). PRTC Series. How to Order. Features. Applications. Notice. Dimensions. Test Circuit. Specifications
Datasheet PRTC Kyocera AVX
MHz Band Ceramic Resonators (SMD) PRTC Series
2.5×2.0×0.8mm Ultra-miniature chip resonator with 0.8mm
How to Order
maximum height Best suited for compact and low profile PRTC 25.00 T R 50 10 W 000 electronic devices ① ② ③ ④ ⑤ ⑥ ⑦ ⑧
Features
①Series ②Oscil ating Frequency (MHz) • Ultra-miniature (2.52.00.8mm) SMD type ③Oscil ating Mode • High precision type is available for ful speed ④Packaging : Tape & Reel USB 4000pcs./Reel ⑤Initial Frequency Tolerance (0.5%)
Applications
⑥Load Capacitance ⑦Operating Temperature (20°C to 80°C) • CD-R/W • Cel ular (CDMA/PCS) ⑧Unique Code RoHS Compliant • HDD • Portable Electronic Equipment • DVD-ROM • Memory Card
Notice
• MD • USB • Printer • Non Washable
Dimensions
(Unit : mm)
Test Circuit
VDD fosc R 1 3 2.00.20 VDD : 5V R : 1M IC : MC74HCU04 (Freescale) 2 ax. 0.8 m 0.4 0.5 0.4
Specifications
• Standard Type ① ③ Input/Output • Standard Type (No polarity)
Frequency Temperature
② GND
Frequency Range Tolerance Stability IC Standard Frequency (
20 to 80°C) (MHz)
• High Precision Type
(25°C)
① Output
25.0 to 60.0MHz
MC74HCU04 0.5% 0.2% 25.0, 30.0, 33.86, 40.0 ② GND (Freescale) ③ Input Please contact your local sales office for IC matching. 2.50.2 • High Precision Type
Frequency Temperature Frequency Range Aging Tolerance Stability IC Standard Frequency (25°C) (
20 to 70°C) (10 years) (MHz) 25.0 to 60.0MHz
0.16% 0.08% 0.01% MC74HCU04 (Freescale) 48.0
Recommended Land Pattern
(Unit : mm)
Recommended Reflow Profile Packaging : Taping
(Unit : mm) 0.5 0.5 0.5 300 2.0 4.0 1.5 2.3 0.3 peak : 260°C max. 250 ) 1.75 (0.3) 0.8 (°C 200 over 230°C 8.0 3.5 20sec. max. 2.7 (0.3) 150 preheat and over 200°C 2.6 perature 150 to 180°C 60sec.max. 100 (5°) 0.9 Tem 60sec. min. 4.0 (5°) (0.3) 50 1.2 (0.3) 0.8 0 Time (sec.) 1.0 1.0 - 24 -
