Datasheet PRTC (Kyocera AVX) - 3
ManufacturerKyocera AVX
DescriptionMHz Band Ceramic Resonators (SMD)
Pages / Page7 / 3 — MHz Band Ceramic Chip Resonators (SMD). PBRC-G / PBRC-L Series. Features. …
File Format / SizePDF / 673 Kb
MHz Band Ceramic Chip Resonators (SMD). PBRC-G / PBRC-L Series. Features. How to Order. Specifications. Test Circuit
MHz Band Ceramic Chip Resonators (SMD) PBRC-G / PBRC-L Series Features How to Order Specifications Test Circuit
for Consumer Applications
• High reliability, high temperature PBRC 15.00 G R 50 Y 000 withstanding ceramic case • Rectangular shape al ows easy pick and ① ② ③ ④ ⑤ ⑥ ⑦ placement ①Series • Smal & low profile ②Frequency (MHz) • Reflow solderable ③Type (G,L) • Excel ent solderability ④Packing _ Bulk (Nickel barrierAu flash terminations) (Nul ) R Reel (G 2k/reel, L 3k/reel) ⑤Frequency Tolerance at 25C
10
0.1%
20
0.2%
30
0.3%
40
0.4% RoHS Compliant
50
0.5%
70
0.7% ⑥Operating Temperature
X
40C to 85C
Y
40C to 125C
Z
40C to 150C ⑦Unique Code
Specifications Test Circuit Series Frequency Frequency Temperature
VDD=5.0V
Range(MHz) Tolerance(25°C) Stability
14 MC14069UB 0.5% 0.5% 2.00 to 8.00 or (op. 0.3%) MC74HCU04
PBRC-G
(40 to 85C) 1 2 3 4 7 0.7% 0.1% 8.01 to 20.0 Out (op. 0.5%) (40 to 85C) Rf Resonator 0.5% 0.5% 4.00 to 8.00 (op. 0.3%) (40 to 85C) C1 C2
PBRC-L
0.7% 0.1% 8.01 to 20.0 Note) (op. 0.5%) (40 to 85C)
PBRC-G Type
• Values of C1, C2 and Rf are evaluated with IC, MC14069UB, Rf 1M and evaluation of circuit is necessary when using other IC’s. C1C230pF(2.00 to 8.00MHz) IC: MC14069UB * Aging for 10 years is within 0.3% from the initial frequency at 25C. C • IC circuit matching may be referenced with 1C210pF (8.01 to 20.0MHz) IC: MC74HCU04 1) IC data books
PBRC-G Type
R 2) List of Recommended circuits in Kyocera website. f 1M C • Please contact IC manufacturer or Kyocera when there are 1C215pF (3.68 to 8.00MHz) IC: MC14069UB C1C210pF(8.01 to 20.0MHz) IC: MC74HCU04 difficulties in finding recommended circuits.
Dimensions
(Unit : mm) (Unit : mm) PBRC-G Type PBRC-L Type
XXXX
3.4
XXX
2.0 1.6 7.4 6.7 4.5 4.1 ax. 0.6 ax. 0.4 2.0m 1.2m R0.2 6-R0.45 1.2 6-0.3 1 3 1 3 0.4 3.0 1.7 2.5 2.5 1.5 1.5 Standard Tol. : 0.3 Standard Tol. : 0.2 Termination : Ni+Au Flash Plating 1. 3 Input, Output (No polarity) - 26 -
