Datasheet PRTC (Kyocera AVX) - 4
ManufacturerKyocera AVX
DescriptionMHz Band Ceramic Resonators (SMD)
Pages / Page7 / 4 — MHz Band Ceramic Chip Resonators (SMD). PBRC-H / PBRC-M / PRQC Series. …
File Format / SizePDF / 673 Kb
MHz Band Ceramic Chip Resonators (SMD). PBRC-H / PBRC-M / PRQC Series. Features. How to Order (PBRC-H,PBRC-M). Test Circuit
MHz Band Ceramic Chip Resonators (SMD) PBRC-H / PBRC-M / PRQC Series Features How to Order (PBRC-H,PBRC-M) Test Circuit
for Consumer Applications
• High reliability, high temperature PBRC 15.00 H R 50 Y 000 withstanding ceramic case ① ② ③ ④ ⑤ ⑥ ⑦ • Rectangular shape al ows easy pick and placement ①Series • Smal & low profile ②Frequency (MHz) • Reflow solderable ③Type (H,M) • Excel ent solderability ④Packing _ Bulk (Nickel barrierAu flash terminations) (Nul ) R Reel (H 2k/reel, M 3k/reel) ⑤Frequency Tolerance at 25C
10
0.1%
20
0.2%
30
0.3%
40
0.4%
50
0.5%
70
0.7% RoHS Compliant ⑥Operating Temperature
Test Circuit Specifications X
40C to 85C
Y
40C to 125C
Z
40C to 150C VDD=5.0V 14
Series Frequency Frequency Temperature Range(MHz) Tolerance(25°C) Stability
⑦Unique Code MC14069UB or MC74HCU04 0.5% 0.5%
How to Order (PRQC)
2.00 to 8.00 (op. 0.3%) (40 to 85C) 1 2 3 4 7 PRQC 8.00 S R 50 10 X 000
PBRC-H
Rf Out 0.7% 0.1% ① ② ③ ④ ⑤ ⑥ ⑦ ⑧ 8.01 to 20.0 Resonator (op. 0.5%) (40 to 85C) ①Series ②Frequency (MHz) 0.5% 0.5% C1 C2 4.00 to 8.00 ③Type (S) (op. 0.3%) (40 to 85C) ④Packing _ Bulk
PBRC-M PBRC-H Type
0.7% 0.1% (Nul ) Rf=1M 8.01 to 20.0 C R Reel (3k/reel) 1C230pF (2.00 to 8.00MHz) IC: MC14069UB (op. 0.5%) (40 to 85C) C1C210pF (8.01 to 20.0MHz) IC: MC74HCU04 ⑤Frequency Tolerance at 25C
PBRC-M Type
 R
10
0.1%
20
0.2% f=1M 0.5% 0.5% 8.00 to 20.0 C1C215pF (3.68 to 8.00MHz) IC: MC14069UB
PRQC
30
0.3%
40
0.4% C1C210pF (8.01 to 20.0MHz) IC: MC74HCU04
PRQC Type 50
0.5%
70
0.7% * Aging for 10 years is within 0.3% from the initial frequency at 25C. Rf=1M C1C210pF (8.00 to 20.0MHz) IC: MC74HCU04 * C1, C2 are for Reference. ⑥Built-in Capacitance 10pF : 10 ⑦Operating Temperature Note)
W
20C to 80C
Y
40C to 125C • This product includes built-in capacitors, but values may not be the most appropriate depending on IC’s.
X
40C to 85C
Z
40C to 150C • Evaluation of circuit with IC is necessary. IC circuit matching may be referenced with ⑧Unique Code 1) IC data books 2) List of Recommended circuits in Kyocera website. • Please contact IC manufacturer or Kyocera when there are difficulties in finding recommended circuits.
Dimensions
(Unit : mm) (Unit : mm) (Unit : mm) PBRC-H Type PBRC-M Type PRQC Type
XXXX
3.4
XXX
2.0 1.6
XXX
1.3 7.4 3.2 6.7 4.5 4.1 0.6 ax. ax. 0.4 1.3 2.0m 1.2m 0.40.1 6-R0.2 3-1.2 6-R0.45 6-0.3 1 2 3 1 2 3 1 2 3 0.4 1.3 3.0 1.7 1.20.1 1.20.1 2.5 2.5 1.5 1.5 Standard Tol. : 0.3 Standard Tol. : 0.2 Standard Tol. : 0.15 Termination : Ni+Au Flash Plating Termination : Ni+Au Flash Plating Termination : Sn Plating 1. 3 Input, Output (No polarity) 1. 3 Input, Output (No polarity)
# Pin # 1
Input
2
Ground
3
Output - 27 -
