Datasheet PRTC (Kyocera AVX) - 5
ManufacturerKyocera AVX
DescriptionMHz Band Ceramic Resonators (SMD)
Pages / Page7 / 5 — MHz Band Ceramic Chip Resonators (SMD). PBRV-H / PBRV-M / PRQV Series. …
File Format / SizePDF / 673 Kb
MHz Band Ceramic Chip Resonators (SMD). PBRV-H / PBRV-M / PRQV Series. Features. How to Order (PBRV-H,PBRV-M). Applications
MHz Band Ceramic Chip Resonators (SMD) PBRV-H / PBRV-M / PRQV Series Features How to Order (PBRV-H,PBRV-M) Applications
for Automotive Applications
• Miniature & low profile PBRV 15.00 H R 50 Y 000 • Rectangular shape al ows easy pick ① ② ③ ④ ⑤ ⑥ ⑦ and placement • Component cost and space saving ①Series (PBRV: Automotive) • High density mounting possible ②Frequency (MHz) • Reflow solderable & washable ③Type (H,M) • High reliability, high temperature ④Packing _ Bulk operating with ceramic case (Nul )
Applications
R Reel (H 2k/reel, M 3k/reel) ⑤Frequency Tolerance at 25C • Automotive • ABS
10
0.1%
20
0.2% • ECU
30
0.3%
40
0.4% RoHS Compliant • Air-Bag System
50
0.5%
70
0.7%
Specifications Test Circuit
⑥Operating Temperature
X
40C to 85C
Y
40C to 125C
Z
40C to 150C VDD=5.0V
Series Frequency Frequency Temperature Range(MHz) Tolerance(25°C) Stability
⑦Unique Code 14 4.00 to 8.00 0.5% Y:0.5%(40 to 125C)
PBRV-H
(op. 0.3%) Z:0.5%(40 to 150C) MC14069UB or MC74HCU04
How to Order (PRQV) PBRV-M
8.01to20.00 0.7% Y:0.1%(40to125C) PRQV 8.00 S R 50 10 Y 000 1 2 3 4 7 (op. 0.5%) Z:0.2%(40 to 150C) ① ② ③ ④ ⑤ ⑥ ⑦ ⑧ Out
PRQV
8.00 to 20.00 0.5% Y:0.5%(40 to 125C) (op. 0.3%) Z:0.5%(40 to 150C) ①Series (PRQV: Automotive) Rf ②Frequency (MHz) * Aging for 10 years is within 0.3% from the initial frequency at 25C. Resonator ③Type (S) * Please contact us for products without built-in capacitors. ④Packing _ Bulk (Nul ) C1 C2 R Reel (3k/reel) ⑤Frequency Tolerance at 25C
PBRV-H Type 10
0.1%
20
0.2% Rf=1M C1C230pF(4.00 to 8.00MHz) IC: MC14069UB Note)
30
0.3%
40
0.4% C1C210pF(8.01 to 20.0MHz) IC: MC74HCU04 • This product includes built-in capacitors, but values may not
50
0.5%
70
0.7%
PBRV-M Type
be the most appropriate depending on IC’s. Rf=1M • Evaluation of circuit with IC is necessary. IC circuit matching C ⑥Built-in Capacitance 10pF : 10 1C215pF (4.00 to 8.00MHz) IC: MC14069UB may be referenced with C1C210pF(8.01 to 20.0MHz) IC: MC74HCU04 ⑦Operating Temperature 1) IC data books
PRQV Type
2) List of Recommended circuits in Kyocera website. Rf=1M
X
40C to 85C
Y
40C to 125C • Please contact IC manufacturer or Kyocera when there are C1C210pF(8.00 to 20.0MHz) IC: MC74HCU04 * C1, C2 are for Reference. difficulties in finding recommended circuits.
Z
40C to 150C ⑧Unique Code
Dimensions
(Unit : mm) (Unit : mm) (Unit : mm) PBRV-H Type PBRV-M Type PRQV Type
XXXX
3.4
XXX
2.0 1.6
XXX
1.3 7.4 4.5 3.2 6.7 4.1 ax. ax. 0.6 0.4 1.3 2.0m 1.2m 6-R0.45 6-R0.2 3-1.2 6-0.3 0.40.1 1 2 3 1 2 3 1 2 3 0.4 1.7 3.0 1.3 1.5 1.5 2.5 2.5 1.20.1 1.20.1 Standard Tol. : 0.3 Standard Tol. : 0.2 Termination : Ni+Au Flash Plating Termination : Ni+Au Flash Plating Standard Tol. : 0.15 1. 3 Input, Output (No polarity) 1. 3 Input, Output (No polarity) Termination : Sn Plating
# Pin # 1
Input
2
Ground
3
Output - 28 -
