Datasheet PRTC (Kyocera AVX) - 6
ManufacturerKyocera AVX
DescriptionMHz Band Ceramic Resonators (SMD)
Pages / Page7 / 6 — MHz Band Ceramic Chip Resonators (SMD). PBRV/ PRQV Frequency Tight …
File Format / SizePDF / 673 Kb
MHz Band Ceramic Chip Resonators (SMD). PBRV/ PRQV Frequency Tight Tolerance Series. Features. How to Order (PBRV)
MHz Band Ceramic Chip Resonators (SMD) PBRV/ PRQV Frequency Tight Tolerance Series Features How to Order (PBRV)
for Automotive Applications
• Improved frequency tolerance for CANBUS PBRV 15.00 H R 10 Y 000 application of automotive ① ② ③ ④ ⑤ ⑥ ⑦ ①Series (PBRV: Automotive) ②Frequency (MHz) ③Type (H,M) ④Packing _ Bulk (Nul ) R Reel (H 2k/reel, M 3k/reel) ⑤Frequency Tolerance at 25C
10
0.1% ⑥Operating Temperature RoHS Compliant
X
40C to 85C
Y
40C to 125C
Z
40C to 150C ⑦Unique Code
How to Order (PRQV)
PRQV 8.00 S R 10 10 Y 000 ① ② ③ ④ ⑤ ⑥ ⑦ ⑧
Specifications
①Series (PRQV: Automotive)
Series PBRV-HR/MR PBRV-HR/MR PRQV-S
②Frequency (MHz)
Part Number PBRV-HR/MR 10Y□□□ PBRV-HR/MR 10Y□□□ PRQV-SR□10Y□□□
③Type (S)
Operating Temperature Range
40 to 125C 40 to 125C 40 to 125C ④Packing _ Bulk
Frequency Range
4.0 to 7.9MHz 8.0 to 20.0MHz 8.0 to 20.0MHz (Nul )
FrequencyTolerance Initial
Temperature
0.3% 0.2% 0.25% R Reel (3k/reel)
Aging
0.1% 0.1% 0.05% ⑤Frequency Tolerance at 25C
Total Frequency Tolerance
0.4% 0.3% 0.3%
10
0.1% * Please refer to the specification sheet of each product for information including detail dimensions. ⑥Built-in Capacitance 10pF : 10 * Aging characteristics is specified at 25C, and for the period of 10 years. ⑦Operating Temperature
X
40C to 85C
Y
40C to 125C
Z
40C to 150C ⑧Unique Code
Dimensions
(Unit : mm) (Unit : mm) (Unit : mm) PBRV-H Type PBRV-M Type PRQV Type
XXXX
3.4
XXX
2.0 1.6
XXX
1.3 7.4 4.5 3.2 6.7 4.1 ax. ax. 0.6 0.4 1.3 2.0m 1.2m 6-R0.45 6-R0.2 3-1.2 6-0.3 0.40.1 1 2 3 1 2 3 1 2 3 0.4 1.7 3.0 1.3 1.5 1.5 2.5 2.5 1.20.1 1.20.1 Standard Tol. : 0.3 Standard Tol. : 0.2 Termination : NiAu Flash Plating Termination : NiAu Flash Plating Standard Tol. : 0.15 1. 3 Input, Output (No polarity) 1. 3 Input, Output (No polarity) Termination : Sn Plating
# Pin # 1
Input
2
Ground
3
Output - 29 -
