Datasheet PRTC (Kyocera AVX) - 7
| Manufacturer | Kyocera AVX |
| Description | MHz Band Ceramic Resonators (SMD) |
| Pages / Page | 7 / 7 — MHz Band Ceramic Chip Resonators (SMD). Recommended Land Pattern / … |
| File Format / Size | PDF / 673 Kb |
MHz Band Ceramic Chip Resonators (SMD). Recommended Land Pattern / Packaging. Recommended Land Pattern. Packaging. Code
MHz Band Ceramic Chip Resonators (SMD) Recommended Land Pattern / Packaging Recommended Land Pattern
(Unit : mm) (Unit : mm) (Unit : mm) PBRC-G Type PBRC-L Type PRQC Type 5.0 PRQV Type 3.0 A 4.0 0.4 2.6 1.7 C 1.7 1.7 1.0 1.0 B A: 8.0 to 12.5MHz 1.20.1 12.51 to 20.0MHz 0.950.1 (Unit : mm) (Unit : mm) B: 8.0 to 12.5MHz 0.40.1 12.51 to 20.0MHz 0.30.1 PBRC-H Type PBRC-M Type C: 8.0 to 12.5MHz 2.0 PBRV-H Type 2.5 2.5 PBRV-M Type 1.5 1.5 12.51 to 20.0MHz 1.6 4.0 0.4 2.6 1.7 1.7 1.5 1.7 1.0 1.0 1.0
Packaging
Reel Taping W1 K D0 P0 T P2 E E C F W A N B0 D T2 A0 P1 D1 W2
Code A N W1 W2 C D E
1.1 7.43.42.0mm 2502.0 802.0 16.5 0.0 23.6max. 13.00.5 21.00.8 2.00.5 0 1 4.52.01.2mm 180 3 60 0 13.00.3 15.41 13.00.2 21.00.8 2.00.5 1 1.0 3.21.31.3mm 1802 60 0 9.0 1.5 140min. 13.00.2 21.00.8 2.00.5
Code A0 B0 W F E P1 P2 P0 D0 D1 T T2 K
7.43.4 0.1 0.1 3.800.1 7.800.1 16.000.3 7.500.1 1.750.1 8.000.1 2.00.1 4.000.1 1.500.0 1.500.0 2.0mm 0.300.05 2.450.2 2.400.2 4.52.0 0.1 2.200.1 4.700.1 12.000.2 5.50.05 1.750.1 4.000.1 2.00.05 4.000.1 1.500.0 1.2mm 1.00.1 0.300.05 1.85max. 1.80max. 3.21.3 0.1 0.2 1.500.1 3.400.1 8.000.2 3.500.05 1.750.1 4.000.1 2.00.05 4.000.1 1.500.0 1.0 0.0 1.3mm 0.250.05 1.30max. 0.900.1 7.43.42.0mmPBRC-G, PBRC-H, PBRV-G, PBRV-H 2000pcs./Reel 4.52.01.2mmPBRC-L, PBRC-M, PBRV-L, PBRV-M 3000pcs./Reel 3.21.31.3mmPRQC-S, PRQV-S 3000pcs./Reel - 30 -
