Datasheet X60003 (Renesas)
ManufacturerRenesas
DescriptionPrecision SOT-23 FGA Voltage References
Pages / Page17 / 1 — 800. HIGH. 700. 600. TYP. nA) 500. ( I N. 400. LOW. 300. 200. 4.0. 5.0. …
File Format / SizePDF / 935 Kb
800. HIGH. 700. 600. TYP. nA) 500. ( I N. 400. LOW. 300. 200. 4.0. 5.0. 6.0. 7.0. 8.0. 9.0. VIN (V)
Datasheet X60003 Renesas
DATASHEET X60003 FN8137 Precision SOT-23 FGA™ Voltage References Rev 5.00 September 1, 2015 The X60003 FGA™ voltage references is a very high precision Features analog voltage reference fabricated in Intersil’s proprietary Floating Gate Analog technology, which achieves superior • Reference output voltage . 4.096V, 5.000V levels of performance when compared to conventional band • Initial accuracy . ±1.0mV (B grade) gap, buried zener, or XFET™ technologies. • Ultra low power supply current. 500nA FGA™ voltage references feature very high initial accuracy, • Low temperature coefficient (B grade) . 10ppm/°C very low temperature coefficient, excellent long term stability, low noise and excellent line and load regulation, at the lowest • 10mA source and sink current capability power consumption currently available. These voltage • Very low dropout voltage. 100mV at No Load references enable advanced applications for precision • Input voltage range industrial and portable systems operating at significantly higher accuracy and lower power levels than can be achieved - X60003-41 . 4.5V to 9.0V with conventional technologies. - X60003-50 . 5.1V to 9.0V Applications • 5kV ESD (human body model) • Standard package . 3 Ld SOT-23 • High resolution A/Ds and D/As • Temp range. -40°C to +85°C • Digital meters • Calibration systems Related Literature • V-F converters • See AN1494, “Reflow and PC Board Assembly Effects on • Precision current sources Intersil FGA References” • Precision regulators • See AN1533, “X-Ray Effects on Intersil FGA References” • Precision oscillators • Smart sensors • Strain gage bridges • Threshold detectors • Battery management systems • Servo systems
800 HIGH 700 600 TYP nA) 500 ( I N 400 LOW 300 200 4.0 5.0 6.0 7.0 8.0 9.0 VIN (V)
FIGURE 1. IIN vs VIN (3 UNITS) FN8137 Rev 5.00 Page 1 of 17 September 1, 2015
