Datasheet X60003 (Renesas) - 4
ManufacturerRenesas
DescriptionPrecision SOT-23 FGA Voltage References
Pages / Page17 / 4 — link. to. page. 5. link. to. page. 5. link. to. page. 5. link. to. page. …
File Format / SizePDF / 935 Kb
link. to. page. 5. link. to. page. 5. link. to. page. 5. link. to. page. 4. link. to. page. 4. link. to. page. 4. link. to. page. 5. link. to. page. 5. link. to. page. 5. link. to. page. 5. link. to
link to page 5 link to page 5 link to page 5 link to page 4 link to page 4 link to page 4 link to page 5 link to page 5 link to page 5 link to page 5 link to
link to page 5 link to page 5 link to page 5 link to page 4 link to page 4 link to page 4 link to page 5 link to page 5 link to page 5 link to page 5 link to page 12 X60003 Absolute Voltage Ratings Thermal Information Max Voltage Applied Thermal Resistance (Typical) JA (°C/W) JC (°C/W) VIN to GND . -0.5V to +10V 3 Lead SOT-23 (Notes 6, 7). 275 110 VOUT to GND (10s). -0.5V to +5.1V Maximum Junction Temperature . .+107°C ESD Ratings Storage Temperature Range. .-65°C to +125°C Human Body Model (Tested to JESD22-A114) . 5kV Pb-Free Reflow Profile . see TB493 Machine Model (Tested to JESD22-A115). 500V Latch Up (Tested per JESD-78B; Class 2, Level A) . 100mA Recommended Operating Conditions Environmental Operating Conditions Temperature Range (Industrial) . -40°C to +85°C X-Ray Exposure (Note 5) . 10mRem CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely impact product reliability and result in failures not covered by warranty. IMPORTANT NOTE: All parameters having Min/Max specifications are guaranteed. Typ values are for information purposes only. Unless otherwise noted, all tests are at the specified temperature and are pulsed tests, therefore: TJ = TC = TA NOTES: 5. Measured with no filtering, distance of 10” from source, intensity set to 55kV and 70mA current, 30s duration. Other exposure levels should be analyzed for Output Voltage drift effects. See “Applications Information” on page 12. 6. JA is measured with the component mounted on a high effective thermal conductivity test board in free air. See Tech Brief TB379 for details. 7. For JC, the “case temp” location is taken at the package top center. 8. Post-reflow drift for the X60003 devices will range from 100µV to 1.0mV based on experimental results with devices on FR4 double sided boards. The design engineer must take this into account when considering the reference voltage after assembly. Electrical Specifications Operating Conditions: IOUT = 0mA, COUT = 0.001µF, TA = -40 to +85°C. Boldface limits apply over the operating temperature range, -40°C to +85°C. MIN MAX SYMBOL PARAMETER CONDITIONS (Note 12) TYP (Note 12) UNITS VOA VOUT Accuracy @ TA = +25°C X60003B -1.0 +1.0 mV X60003C -2.5 +2.5 mV X60003D -5.0 +5.0 mV IIN Supply Current 500 900 nA TC VOUT Output Voltage Temperature Coefficient X60003B 10 ppm/°C (Note 9) X60003C 20 ppm/°C X60003D 20 ppm/°C VN Output Voltage Noise 0.1Hz to 10Hz 30 µVP-P ISC Short Circuit Current TA = +25°C 50 80 mA Electrical Specifications (X60003-41) VIN = 5.0, TA = -40°C to +85°C, unless otherwise specified. Boldface limits apply over the operating temperature range, -40°C to +85°C. MIN MAX SYMBOL PARAMETER CONDITIONS (Note 12) TYP (Note 12) UNITS VIN Input Voltage Range 4.5 9.0 V VOUT Output Voltage 4.096 V VOUT/VIN Line Regulation +4.5V  VIN  +8.0V 150 µV/V VOUT/IOUT Load Regulation Sourcing: 0mA  ISOURCE  10mA 10 50 µV/mA Sinking: -10mA  ISINK  0mA 20 100 µV/mA VOUT/TA Thermal Hysteresis (Note 10) T = -40°C to +85°C 150 ppm VOUT/t Long Term Stability (Note 11) TA = +25°C 50 ppm FN8137 Rev 5.00 Page 4 of 17 September 1, 2015
