Datasheet X60003 (Renesas) - 5
ManufacturerRenesas
DescriptionPrecision SOT-23 FGA Voltage References
Pages / Page17 / 5 — link. to. page. 5. link. to. page. 5. link. to. page. 5. link. to. page. …
File Format / SizePDF / 935 Kb
link. to. page. 5. link. to. page. 5. link. to. page. 5. link. to. page. 5. X60003. Electrical. Specifications. (X60003-50). VIN. =. 6.5V,. TA. =. -40°C. to. +85°C,. unless
link to page 5 link to page 5 link to page 5 link to page 5 X60003 Electrical Specifications (X60003-50) VIN = 6.5V, TA = -40°C to +85°C, unless
link to page 5 link to page 5 link to page 5 link to page 5 X60003 Electrical Specifications (X60003-50) VIN = 6.5V, TA = -40°C to +85°C, unless otherwise specified. Boldface limits apply over the operating temperature range, -40°C to +85°C. MIN MAX SYMBOL PARAMETER CONDITIONS (Note 12) TYP (Note 12) UNITS VIN Input Voltage Range 5.1 9.0 V VOUT Output Voltage 5.000 V VOUT/VIN Line Regulation +5.5V  VIN  +8.0V 150 µV/V VOUT/IOUT Load Regulation Sourcing: 0mA ISOURCE  10mA 10 50 µV/mA Sinking: -10mA  ISINK  0mA 20 100 µV/mA VDO Dropout Voltage IOUT = 5mA, VOUT = -0.01% 150 300 mV VOUT/TA Thermal Hysteresis (Note 10) T = -40°C to +85°C 100 ppm VOUT/t Long Term Stability (Note 11) TA = +25°C 45 ppm NOTES: 9. Over the specified temperature range. Temperature coefficient is measured by the box method whereby the change in VOUT is divided by the temperature range; in this case, -40°C to +85°C = +125°C. 10. Thermal Hysteresis is the change of VOUT measured at TA = +25°C after temperature cycling over a specified range, TA. VOUT is read initially at TA = +25°C for the device under test. The device is temperature cycled and a second VOUT measurement is taken at +25°C. The difference between the initial VOUT reading and the second VOUT reading is then expressed in ppm. For  TA = +125°C, the device under test is cycled from +25°C to +85°C to -40°C to +85°C. 11. Long term drift is logarithmic in nature and diminishes over time. Drift after the first 1000 hours will be approximately 10ppm/sqrt(1kHrs). 12. Parameters with MIN and/or MAX limits are 100% tested at +25°C, unless otherwise specified. Temperature limits established by characterization and are not production tested. FN8137 Rev 5.00 Page 5 of 17 September 1, 2015
