Datasheet MAX873, MAX875, MAX876 (Analog Devices) - 4
| Description | Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage Reference |
| Pages / Page | 12 / 4 — Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage References. … |
| File Format / Size | PDF / 388 Kb |
Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage References. Typical Operating Characteristics
Low-Power, Low-Drift, +2.5V/+5V/+10V Precision Voltage References Typical Operating Characteristics
(VIN = +5V for VOUT = +2.5V, VIN = +15V for VOUT = +10V, IOUT = 0, TA = +25°C, unless otherwise noted.)
OUTPUT VOLTAGE vs. TEMPERATURE OUTPUT VOLTAGE vs. TEMPERATURE LOAD REGULATION vs. (VOUT = 2.5V) (VOUT = 10V) SOURCE CURRENT (VOUT = 2.5V)
2.502 10.003 0.50 10.002 10.001 2.501 TA = -40°C MAX873/75/76 toc01 MAX873/75/76 toc02 0.25 MAX873/75/76 toc03 10.000 TA = +25°C 9.999 2.500 9.998 0 9.997 OUTPUT VOLTAGE (V) 9.996 OUTPUT VOLTAGE (V) 2.499 -0.25 9.995 OUTPUT VOLTAGE CHANGE (mV) TA = +125°C 9.994 THREE TYPICAL PARTS THREE TYPICAL PARTS 2.498 9.993 -0.50 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 0 5 10 15 20 25 30 TEMPERATURE (°C) TEMPERATURE (°C) SOURCE CURRENT (mA)
LOAD REGULATION LOAD REGULATION LOAD REGULATION vs. SOURCE CURRENT (VOUT = 10V) vs. SINK CURRENT (VOUT = 2.5V) vs. SINK CURRENT (VOUT = 10V)
0.50 1.00 2.0
MAX873/MAX875/MAX876
TA = +25°C 0.75 1.5 0.25 T MAX873/75/76 toc04 MAX873/75/76 toc05 A = -40°C MAX873/75/76 toc06 T 0.50 T 1.0 A = +125°C A = +25°C T T A = +125°C A = +125°C 0 0.25 0.5 0 0 TA = +25°C -0.25 TA = -40°C OUTPUT VOLTAGE CHANGE (mV) T OUTPUT VOLTAGE CHANGE (mV) OUTPUT VOLTAGE CHANGE (mV) A = -40°C -0.25 -0.5 -0.50 -0.50 -1.0 0 5 10 15 20 25 30 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 2.0 SOURCE CURRENT (mA) SINK CURRENT (mA) SINK CURRENT (mA)
LINE REGULATION vs. TEMPERATURE LINE REGULATION vs. TEMPERATURE MINIMUM INPUT-OUTPUT DIFFERENTIAL (VOUT = 2.5V) (VOUT = 10V) vs. SOURCE CURRENT (VOUT = 2.5V)
100 300 2.5 250 V) 80 V) µ µ MAX873/75/76 toc07 T 2.0 T A = +125°C MAX873/75/76 toc08 MAX873/75/76 toc09 A = -40°C T 200 A = +125°C 60 T T A = +125°C 150 A = -40°C 1.5 T 40 A = +25°C 100 DROPOUT VOLTAGE (V) 1.0 T 20 A = -40°C OUTPUT VOLTAGE CHANGE ( OUTPUT VOLTAGE CHANGE ( 50 T TA = +25°C A = +25°C 0 0 0.5 0 5 10 15 20 25 30 35 40 12 16 20 24 28 32 36 40 0 4 8 12 16 20 INPUT VOLTAGE (V) INPUT VOLTAGE (V) SOURCE CURRENT (mA)
4 _______________________________________________________________________________________
