Datasheet AP431I (Diodes)
| Manufacturer | Diodes |
| Description | Low Cathode Current Adjustable Precision Shunt Regulator |
| Pages / Page | 17 / 1 — NOT RECOMMENDED FOR NEW DESIGN. USE AP431S. AP431i. LOW CATHODE CURRENT … |
| File Format / Size | PDF / 603 Kb |
NOT RECOMMENDED FOR NEW DESIGN. USE AP431S. AP431i. LOW CATHODE CURRENT ADJUSTABLE PRECISION SHUNT REGULATOR. Description
NOT RECOMMENDED FOR NEW DESIGN USE AP431S AP431i LOW CATHODE CURRENT ADJUSTABLE PRECISION SHUNT REGULATOR Description Pin Assignments
The AP431i is a 3-terminal adjustable shunt regulator with guaranteed thermal stability over a full operation range. It features sharp turn-on
(Top View) (Top View)
characteristics, low temperature coefficient and low output imped- AN ODE ANODE ance, which makes it ideal substitute for Zener diode in applications 3 3 such as switching power supply, charger and other adjustable regulators. The AP431i has the same electrical specifications as the industry standard 431 except that it features a low minimum cathode current 1 2 1 2 for regulation. The typical value of 50μA makes the parts ideal for REF CATHODE CATHODE REF very low power dissipation applications.
SOT-23 (Package Code: N) SOT-23 (Package Code: N1)
The output voltage of AP431i can be set to any value between VREF (2.5V/2.495V) and the corresponding maximum cathode voltage
(36V). The AP431i is offered in two grade initial voltage tolerance at +25°C, 0.5% and 1%. This IC is available in 3 packages: TO-92 (ammo packing), SOT-23 1 2 3 and SOT-89. 1 2 3 REF ANODE CATHODE REF ANODE CATHODE
Features SOT-89 (Option 1) SOT-89 (Option 2)
Low Minimum Cathode Current for Regulation: 50μA (Typ.), 100μA (Max.)
(Top View)
Programmable Precise Output Voltage from 2.5V/2.495V to 36V High Stability Under Capacitive Load Low Deviation of Reference Voltage Over Full Temperature Range: 11mV Typical (-40C to +125°C) Sink Current Capacity from 100µA to 100mA Low Dynamic Impedance: 0.1Ω (Typ.) Wide Operating Temperature Range: -40°C to +125°C
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) TO-92 (Ammo Packing) Halogen and Antimony Free. “Green” Device (Note 3
Applications
Charger Voltage Adapter Switching Power Supply Graphic Card Precision Voltage Reference Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS) & 2011/65/EU (RoHS 2) compliant. 2. See http://www.diodes.com/quality/lead_free.html for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AP431i 1 of 17 July 2017 Document number: DS37535 Rev. 7 - 3
www.diodes.com
© Diodes Incorporated
