Datasheet ZXRE250, ZXRE252 (Diodes) - 2
| Manufacturer | Diodes |
| Description | Very Low Cathode Current adjustable Precision Shunt Regulator |
| Pages / Page | 12 / 2 — ZXRE250 / ZXRE252. Absolute Maximum Ratings. Symbol. Parameter. Rating. … |
| File Format / Size | PDF / 747 Kb |
ZXRE250 / ZXRE252. Absolute Maximum Ratings. Symbol. Parameter. Rating. Unit. Recommended Operating Conditions. Min. Max
ZXRE250 / ZXRE252 Absolute Maximum Ratings
(Note 4) (@TA = +25°C, unless otherwise specified.)
Symbol Parameter Rating Unit
VKA Cathode Voltage 40 V IKA Continuous Cathode Current 150 mA IREF Reference Input Current -0.050 to +10 mA TJ Operating Junction Temperature +150 °C TST Storage Temperature -55 to +150 °C SOT23 330 mW PD Power Dissipation (Notes 5 & 6) SOT25 500 mW Notes: 4. Operation above the absolute maximum rating may cause device failure. Operation at the absolute maximum ratings, for extended periods, may reduce device reliability. Unless otherwise stated voltages specified are relative to the ANODE pin. 5. TJ, max = +150°C 6. Ratings apply to ambient temperature at +25°C.
Symbol Parameter Min Max Unit
VKA Cathode Voltage VREF 36 V IKA Cathode Current 0.065 100 mA TA Operating Ambient Temperature -40 +125 °C
Electrical Characteristics
Symbol Parameter Test Conditions Min Typ Max Unit
VKA = VREF, ZXRE250A 2.470 2.495 2.520 V VREF Reference Voltage IKA = 10mA ZXRE250B 2.482 2.495 2.507 V TA = 0 to +70°C — 6 16 mV Deviation of Reference Voltage Over Full VKA = VREF, VDEV T Temperature Range (Note 7) A = -40 to +85°C — 14 34 mV IKA = 10mA TA = -40 to +125°C — 14 34 mV ΔVREF Ratio of the Change in Reference VKA = 10V to VREF — -1.4 -2.7 mV/V ΔV Voltage to the Change in Cathode I KA KA = 10mA Voltage VKA = 36V to 10V — -1 -2 mV/V IREF Reference Input Current IKA = 10mA, R1 = 10KΩ, R2 = ∞ — 1 4 µA TA = 0 to +70°C — 0.8 1.2 µA Δ I I I REF Deviation Over Full Temperature KA = 10mA, R1 = REF T Range (Note 7) 10KΩ, R2 = ∞ A = -40 to +85°C — 0.8 2.5 µA TA = -40 to +125°C — 0.8 2.5 µA IKA(MIN) Minimum Cathode Current for Regulation VKA = VREF — 40 65 µA IKA(OFF) Off-State Current VKA = 36V, VREF = 0V — 0.05 0.5 µA |ZKA| Dynamic Output Impedance (Note 8) VKA = VREF, f = 0Hz — 0.2 0.5 Ω SOT23 — 380 — °C/W ϴJA Thermal Resistance Junction to Ambient SOT25 — 250 — °C/W Notes: 7. Deviation of VDEV, and ΔIREF are defined as the maximum variation of the values over the full temperature range. 8. Derivation of ZKA on following page. ZXRE250 / ZXRE252 2 of 12 June 2018 Document number: DS35228 Rev. 7 - 3
www.diodes.com
© Diodes Incorporated Document Outline Pin Assignments Description Features Applications (2) Package Type: SOT23 (2) Package Types: SOT23
