Datasheet ZXRE250, ZXRE252 (Diodes) - 8
| Manufacturer | Diodes |
| Description | Very Low Cathode Current adjustable Precision Shunt Regulator |
| Pages / Page | 12 / 8 — ZXRE250 / ZXRE252. Application Information. Higher Current. Shunt … |
| File Format / Size | PDF / 747 Kb |
ZXRE250 / ZXRE252. Application Information. Higher Current. Shunt Regulator. Output Control of a Three. Series Regulator
ZXRE250 / ZXRE252 Application Information
V+ V V V OUT + OUT R1 R1 VREF VREF R2 R2 R1 V 1 R1 OUT = ( + ) V 1 OUT = ( + ) R2 VREF R2 VREF
Higher Current Shunt Regulator Shunt Regulator
V+ ZSR*** V+ In Out VOUT 30Ω Common R1 0.01µF Rb VREF R1 VOUT R2 VREF R2 VOUT(min) = VREF + VREG R1 V 1 OUT = ( + ) R2 VREF R1 V 1 OUT = ( + ) Rb - Optional to provide minimum cathode current R2 VREF
Output Control of a Three Series Regulator Terminal Fixed Regulator
V+ R1B V+ R1A VREF Output Output VREF Input V ~ R2A R2B ON ~ 2V V V 2.5V OFF = V+ TH= R1B Low Limit = 1 ( + ) R2B VREF R1A High Limit= 1 ( + )V
Single Supply Comparator
R2A REF
with Temperature Over Voltage / Under Compensated Threshold Voltage Protection Circuit
ZXRE250 / ZXRE252 8 of 12 June 2018 Document number: DS35228 Rev. 7 - 3
www.diodes.com
© Diodes Incorporated Document Outline Pin Assignments Description Features Applications (2) Package Type: SOT23 (2) Package Types: SOT23
