Datasheet TS432AIX, TS432BIX (Taiwan Semiconductor)
ManufacturerTaiwan Semiconductor
Description1.24V Programmable Shunt Voltage Reference
Pages / Page9 / 1 — TS432xIX. 1.24V Programmable Shunt Voltage Reference. DESCRIPTION. …
File Format / SizePDF / 590 Kb
TS432xIX. 1.24V Programmable Shunt Voltage Reference. DESCRIPTION. FEATURES. APPLICATION. SOT-23. Pin Definition:. Notes:
Datasheet TS432AIX, TS432BIX Taiwan Semiconductor
TS432xIX
1.24V Programmable Shunt Voltage Reference DESCRIPTION FEATURES
The TS432AIX and TS432BIX is a three-terminal ● Precision Reference Voltage adjustable shunt regulator with specified thermal TS432AI – 1.24V±1% stability. The output voltage may be set to any value TS432BI – 1.24V±0.5% between V ● REF (approximately 1.24V) and 18V with two Minimum cathode current: 20µA(typ.) external resistors. The TS432AIX and TS432BIX has a ● Equivalent full range Temp. coefficient: 50ppm/ºC typical output impedance of 0.05Ω. Active output ● Programmable output voltage up to 18V circuitry provides a very sharp turn-on characteristic, ● Fast turn-on response making the TS432AIX and TS432BIX excellent ● Sink current capability of 80µA to 100mA replacement for zener diode in many applications. ● Low dynamic output impedance: 0.2Ω ● Low output noise ● Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21
APPLICATION
● SMPS ● Lighting ● Telecommunication ● Home appliance
SOT-23 Pin Definition:
1. Reference 2. Cathode 3. Anode
Notes:
MSL 1 (Moisture Sensitivity Level) per J-STD-020
SIMPLIFIED SCHEMATIC
1 Version: E1811
