Datasheet BIDW30N60T (Bourns) - 4
ManufacturerBourns
DescriptionInsulated Gate Bipolar Transistor (IGBT)
Pages / Page10 / 4 — BIDW30N60T Insulated Gate Bipolar Transistor (IGBT). Electrical …
BIDW30N60T Insulated Gate Bipolar Transistor (IGBT). Electrical Characteristic Performance (continued)
BIDW30N60T Insulated Gate Bipolar Transistor (IGBT) Electrical Characteristic Performance (continued)
BIDW30N60T Insulated Gate Bipolar Transistor (IGBT) Electrical Characteristic Performance (continued) Typical VCE(sat) vs VGE @ TC = 25 °C Typical VCE(sat) vs VGE @ TC = 125 °C
15 15 Common Emitter Common Emitter TC = 25 °C TC = 125 °C (V) (V) CE(sat) I CE(sat) I 10 C = 15 A C = 15 A I 10 C = 30 A IC = 30 A IC = 60 A IC = 60 A 5 5 Collector-emitter Voltage – V Collector-emitter Voltage – V 0 0 4 8 12 16 20 4 8 12 16 20 Gate-emitter Voltage – VGE (V) Gate-emitter Voltage – VGE (V)
Typical VCE(sat) vs Case Temperature Typical Capacitance Characteristics
3.0 2500 Common Emitter Common Emitter V Cies GE = 15 V V 60 A GE = 0 V, f = 1 MHz (V) T 2000 C = 25 °C 2.5 ce(sat) 1500 2.0 Coes 30 A 1000 Capacitance (pF) 1.5 500 Collector-emitter Voltage – V Cres IC = 15 A 1.0 0 25 50 75 100 125 1 10 100 Case Temperature – TC (°C) Collector-emitter Voltage – VCE (V) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
