Datasheet AH4930 (Diodes)
| Manufacturer | Diodes |
| Description | 3D Magnetic Linear Hall Sensor with I2C Interface |
| Pages / Page | 23 / 1 — AH4930. 3D MAGNETIC LINEAR. HALL SENSOR WITH I2C INTERFACE. Description. … |
| File Format / Size | PDF / 1.1 Mb |
AH4930. 3D MAGNETIC LINEAR. HALL SENSOR WITH I2C INTERFACE. Description. Pin Assignments. (Top View). SOT26 (Type A1). Features
AH4930 3D MAGNETIC LINEAR HALL SENSOR WITH I2C INTERFACE Description Pin Assignments
The AH4930 3D magnetic chip is a miniature monolithic sensor IC sensitive to the three orthogonal components of the flux density applied to the IC. On-chip integrated temperature sensor data is available for system functions such as junction temperature indication and
(Top View)
temperature compensation of magnetic field measurement. A precision analog signal-path along with integrated ADC digitizes the measured analog magnetic field values, and this allows the AH4930 with the SCL/INT 1 6 SDA correct magnetic circuit to decode the absolute position of any moving magnet. With its magnetic field detection in x, y, and z-direction the sensor reliably measures three-dimensional, linear and rotation GND 2 AH4930 5 GND movements. GND 3 7 4 VDD The AH4930 measurement data can be read over I2C bus. The sensor is runtime programmable and offers on-chip temperature compensation of the measured units. The selectable power mode
SOT26 (Type A1)
control unit enables micro-power and continuous measurement functionality. Applications include joysticks, control elements (white goods, multifunction knops), or electric meters (anti-tampering) and any other application that requires accurate angular measurements or low power consumptions.
Features Applications
• 3D magnetic flux density sensing • Knobs/levers • Low power-down current 9nA typical • Joysticks with push • Very low power consumption = 13μA during operation (10Hz, • Rotaries with push typ) • Linear (long strokes) • Digital output via standard I2C interface up to 1 Mbit/sec • Stalk gear shifters • 12-bit data resolution for each measurement direction • Shifter position sensors • Bx, By and Bz linear field measurement up to +-1300Gs • Robotics shaft positions • Different power modes and variable update frequencies • Flap positions • Supply voltage range = 2.8V to 5.5V, temperature range TJ = • Mirror positions -40°C to +125°C • Flow meters • Small, industrial 6-pin SOT26 (Type A1) package • Load detection • Interrupt signal available to wake up a microcontroller to save • Water levels system power and watch dog in wake-up mode • Multimedia rotaries/push selectors • Temperature measurement • Door handles & door locks •
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
• Motor commutation •
Halogen and Antimony Free. “Green” Device (Note 3)
• Power tools (speed, torque, direction selections) •
For automotive applications requiring specific change
• 2-wheelers (throttle controls, multifunction switchgears)
control (i.e. parts qualified to AEC-Q100/101/104/200, PPAP capable, and manufactured in IATF 16949 certified facilities), please contact us or your local Diodes representative. https://www.diodes.com/quality/product-definitions/
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AH4930 1 of 23 January 2025 Document number: DS46768 Rev. 1 - 2
www.diodes.com
