Datasheet AH4930 (Diodes) - 6
| Manufacturer | Diodes |
| Description | 3D Magnetic Linear Hall Sensor with I2C Interface |
| Pages / Page | 23 / 6 — AH4930. Magnetic Characteristics. X Axis. Y Axis. Z Axis. Figure 2. … |
| File Format / Size | PDF / 1.1 Mb |
AH4930. Magnetic Characteristics. X Axis. Y Axis. Z Axis. Figure 2. Definition of Magnetic Field Direction. Symbol. Parameter
AH4930 Magnetic Characteristics
(Notes 10 and 11) (TA = +25°C, VDD = 3.3V, unless otherwise specified.) Standard convention for representing the direction of magnetic field strength and flux density by positive and negative signs is as follows: A positive field is considered as South-Pole facing the corresponding Hall element and Figure 2 shows the definition of magnetic directions X, Y, Z of the AH4390.
X Axis Y Axis Z Axis Figure 2. Definition of Magnetic Field Direction
(VDD = 3.3V @TA = +25°C, unless otherwise specified. Magnetic range = +-1300 Gauss)
Symbol Parameter Condition Min Typ Max Unit
Bxyz_lin (Note 12) Usable linear magnetic range Bx, By, Bz — +/-1300 — Gauss Bo_xy Offset Bx, By -15 +-2 15 Gauss Bo_z Offset Bz -10 +-2 10 Gauss Sx, Sy, Sz Sensitivity X, Y, Z Bx, By, Bz — 1 — LSB/G Res12 Resolution 12bit — — 1 — G/LSB Bn Magnetic noise (rms = 1 sigma) Bx, By, Bz — 1 — Gauss Notes: 10. Typical data is at TA = +25C, VDD = 3.3V. 11. Maximum and minimum parameter values over operating temperature range are not tested in production; they are guaranteed by design. The magnetic characteristics may vary with supply, operating temperature and after soldering. 12. Not subject to production test, verified by design/characterization. AH4930 6 of 23 January 2025 Document number: DS46768 Rev. 1 - 2
www.diodes.com
