Datasheet OPV (TT Electronics)
| Manufacturer | TT Electronics |
| Description | Vertical Cavity Surface Emitting Laser |
| Pages / Page | 6 / 1 — Vertical Cavity Surface Emitting Laser. Features:. Description:. OPV300 / … |
| File Format / Size | PDF / 490 Kb |
Vertical Cavity Surface Emitting Laser. Features:. Description:. OPV300 / OPV310 / OPV314. OPV300. OPV310. OPV314. OPV310 / OPV314
OPV300, OPV310, OPV310Y, OPV314, OPV314Y
Features:
• 850nm VCSEL Technology • Data rates up to 2.5 Gbps • High thermal stability • Low drive current / high output density • Narrow and concentric beam angle • Recommended for multimode fiber applications • Burned in for communication level reliability
Description:
The
series are high performance 850nm Vertical Cavity Surface Emitting Laser (VCSEL). The
OPV300
and
OPV310
are designed to be utilized for sensing applications as well as air transmission of data. The
OPV314
is designed for high speed communication links. The
OPV310 / OPV314
combine all the performance advantages of a VCSEL with the addition of a power monitor diode for precise control of optical power. The
OPV310 and OPV314
have a back monitor photodiode used for optical power management or optical reception for data communication applications. The
OPV300 / OPV310
have a flat lens while the
OPV314
has a microbead lens. Refer to mechanical drawings for details. The high performance 850nm VCSEL is designed for applications where low current is required with high on-axis optical power. These product’s combine features including high speed, high output optical power and concentric beam making it an ideal transmitter for integration into all types of data communications equipment as well as for reflective and transmissive switches.
Applications:
• Fiber Channel • Gigabit Ethernet • ATM • VSR • Intra-System links • Optical backplane interconnects • Reflective sensing • Interruptive sensing • Long distance spot illumination NO TICE This component is sensitive to electrostatic discharge (ESD). To prevent ESD-induced damage and/ or degradation to equipment, take normal ESD precautions when handling this product. Additional laser safety information can be found on the Optek website. See application bulletin #221. Classification is not marked on the device due to space limitations. See package outline for centerline of optical radiance. Operating devices beyond maximum rating may result in hazardous radiation exposure.
RoHS
General Note TT Electronics | OPTEK Technology TT Electronics reserves the right to make changes in product specification without 2900 E. Plano Pkwy, Plano, TX 75074 | Ph: +1 972 323 2200 notice or liability. All information is subject to TT Electronics’ own data and is www.ttelectronics.com | sensors@ttelectronics.com considered accurate at time of going to print. © TT electronics plc Rev C 7/2018 Page 1
