Datasheet MAX5362 (Analog Devices) - 2
DescriptionLow-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package
Pages / Page13 / 2 — Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 …
File Format / SizePDF / 214 Kb
Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package. ABSOLUTE MAXIMUM RATINGS
Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package ABSOLUTE MAXIMUM RATINGS
VDD to GND ..-0.3V to +6V Operating Temperature Range OUT to GND ...-0.3V to (VDD + 0.3V) MAX536__EUK-T ..-40°C to +85°C SCL, SDA to GND...-0.3V to +6V Storage Temperature Range ...-65°C to +150°C Maximum Current into Any Pin..50mA Maximum Junction Temperature ...+150°C Continuous Power Dissipation (TA = +70°C) Lead Temperature (soldering, 10s) ...+300°C 5-Pin SOT23 (derate 7.1mW/°C above +70°C)...571mW Soldering Temperature (reflow) ...+260°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
ELECTRICAL CHARACTERISTICS
(VDD = 2.7V to 3.6V (MAX5360); VDD = 4.5V to 5.5V (MAX5361); VDD = 2.7V to 5.5V (MAX5362); RL =10kΩ, CL = 50pF, TA = TMIN to TMAX, unless otherwise noted. Typical values are TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS STATIC ACCURACY
Resolution 6 Bits Integral Linearity Error INL (Note 1) ±1 LSB Differential Linearity Error DNL Guaranteed monotonic (Note 2) ±1 LSB Offset Error VOS Guaranteed monotonic (Note 2) ±1 ±25 mV Offset Error Supply Rejection MAX5362 (Notes 2, 3) 60 dB MAX5360/MAX5361 3 Offset Error Temperature (Note 2) ppm/°C Coefficient MAX5362 1 MAX5360/MAX5361 10 % of Ideal Full-Scale Error Code = 63 FS MAX5362 5
MAX5360/MAX5361/MAX5362
Full-Scale Error Supply Rejection Code = 63, MAX5360/MAX5361 (Note 4) 60 dB Full-Scale Error Temperature MAX5360/MAX5361 ±40 Code = 63 ppm/°C Coefficient MAX5362 ±10
DAC OUTPUT
MAX5360 1.8 2 2.2 MAX5361 3.6 4 4.4 Internal Reference (Note 5) REF V 0.85 0.9 0.95 MAX5362 VDD VDD VDD Code = 63, 0 to 100µA 0.5 Output Load Regulation LSB Code = 0, 0 to -100µA 0.5 Output Resistance VOUT = 0 to VDD, power-down mode 10 kΩ
DYNAMIC PERFORMANCE
Voltage Output Slew Rate Positive and negative 0.4 V/µs Output Settling Time To 1/2LSB, 50kΩ and 50pF load (Note 6) 20 µs Digital Feedthrough Code = 0, all digital inputs from 0 to VDD 2 nVs Digital-Analog Glitch Impulse Code 31 to 32 40 nVs Wake-Up Time From software shutdown 50 µs
2 _______________________________________________________________________________________
