Datasheet MAX5362 (Analog Devices) - 5
| Description | Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package |
| Pages / Page | 13 / 5 — Low-Cost, Low-Power 6-Bit DACs with. 2-Wire Serial Interface in SOT23 … |
| File Format / Size | PDF / 214 Kb |
Low-Cost, Low-Power 6-Bit DACs with. 2-Wire Serial Interface in SOT23 Package. MAX5360/MAX5361/MAX5362
Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package MAX5360/MAX5361/MAX5362 Typical Operating Characteristics (continued)
(VDD = 3V (MAX5360), VDD = 5V (MAX5361/MAX5362), TA = +25°C, unless otherwise noted.)
DIFFERENTIAL NONLINEARITY DIFFERENTIAL NONLINEARITY DIFFERENTIAL NONLINEARITY vs. CODE vs. SUPPLY VOLTAGE vs. TEMPERATURE
0 0 0.010 MAX5360/1/2-04 -0.005 -0.005 0.005 MAX5360/1/2-05 MAX5360/1/2-06 0 -0.010 -0.010 -0.005 DNL (LSB) DNL (LSB) -0.015 DNL (LSB) -0.015 -0.010 -0.020 -0.020 -0.015 -0.020 -0.025 -0.025 0 25 50 75 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 CODE SUPPLY VOLTAGE (V) TEMPERATURE (°C)
TOTAL UNADJUSTED ERROR vs. CODE OFFSET ERROR vs. SUPPLY VOLTAGE OFFSET ERROR vs. TEMPERATURE
0.15 0 0 0.10 MAX5360/1/2-07 MAX5360/1/2-08 MAX5360/1/2-09 0.05 0 (mV) -0.25 V OS -0.25 -0.05 TUE (LSB) V OS -0.10 -0.15 -0.20 -0.50 -0.50 0 25 50 75 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 CODE SUPPLY VOLTAGE (V) TEMPERATURE (°C)
FULL-SCALE ERROR vs. TEMPERATURE FULL-SCALE ERROR vs. TEMPERATURE SUPPLY CURRENT vs. SUPPLY VOLTAGE
MAX5360/1/2-10 MAX5360/1/2-11 0.75 1.2 0.75 1.2 200 MAX5361 180 0.50 0.8 0.50 0.8 MAX5361 MAX5360 160 MAX5360/1/2-12 MAX5360 ) 140 0.25 0.4 ( 0.25 MAX5360 0.4 μA) MAX5362 O MAX5361 120 MAX5362 0 0 0 0 100 MAX5362 SC 80 -0.25 -0.4 -0.25 -0.4 60 SUPPLY CURRENT ( FULL-SCALE ERROR (LSB) FULL-SCALE ERROR (LSB) FULL-SCALE ERROR (%) 40 -0.50 -0.8 -0.50 -0.8 NO LOAD 20 -0.75 -1.2 -0.75 -1.2 0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 2.5 3.0 3.5 4.0 4.5 5.0 5.5 SUPPLY VOLTAGE (V) TEMPERATURE (°C) SUPPLY VOLTAGE (V)
_______________________________________________________________________________________ 5
