Datasheet MAX5362 (Analog Devices) - 6
| Description | Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package |
| Pages / Page | 13 / 6 — Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 … |
| File Format / Size | PDF / 214 Kb |
Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package Typical Operating Characteristics (continued)
(VDD = 3V (MAX5360), VDD = 5V (MAX5361/MAX5362), TA = +25°C, unless otherwise noted.)
SHUTDOWN SUPPLY CURRENT SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. CODE vs. SUPPLY VOLTAGE
160 160 1.0 MAX5361 MAX5362 155 155 VDD = 5V MAX5360/1/2-13 MAX5360/1/2-14 V 08 DD = 5V MAX5360/1/2-15 μA) MAX5361 150 μA) 150 μA) 0.6 145 MAX5362 145 0.4 140 MAX5360 140 SUPPLY CURRENT ( SUPPLY CURRENT ( MAX5360 MAX5360 SUPPLY CURRENT ( VDD = 5V VDD = 3V 0.2 135 135 130 130 0 -40 -20 0 20 40 60 80 100 0 8 16 24 32 40 48 56 64 2.5 3.0 3.5 4.0 4.5 5.0 5.5 TEMPERATURE (°C) CODE SUPPLY VOLTAGE (V)
SHUTDOWN SUPPLY CURRENT vs. TEMPERATURE OUTPUT LOAD REGULATION OUTPUT VOLTAGE ON POWER-UP
MAX5360/1/2-17 1.0 4.5 A 4.0 0.8 MAX5360/1/2-16 3.5 MAX5360/1/2-18 OUT
MAX5360/MAX5361/MAX5362
μA) 3.0 50mV/div 0.6 FULL SCALE (V) 2.5 VDD = 5V B V OUT 2.0 0.4 C 1.5 0.2 VDD V 2V/div SUPPLY CURRENT ( DD = 3V D 0.2 E 0.1 ZERO CODE (V) 0 0 V OUT -40 -20 0 20 40 60 80 100 0 1 2 3 4 5 6 7 8 9 10 4μs/div TEMPERATURE (°C) LOAD CURRENT (mA) A: MAX5361/MAX5362, VDD = 4.5V, FULL-SCALE OR SOURCIN B: MAX5360, FULL-SCALE, VDD = 2.7V SINKING, VDD = 5V SO C: MAX5360, FULL-SCALE, VDD = 2.7V, SOURCING D: ZERO CODE, VDD = 2.7V, SINKING E: ZERO CODE, VDD = 5.5V SINKING
6 _______________________________________________________________________________________
