Datasheet MAX5362 (Analog Devices) - 7
| Description | Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package |
| Pages / Page | 13 / 7 — Low-Cost, Low-Power 6-Bit DACs with. 2-Wire Serial Interface in SOT23 … |
| File Format / Size | PDF / 214 Kb |
Low-Cost, Low-Power 6-Bit DACs with. 2-Wire Serial Interface in SOT23 Package. MAX5360/MAX5361/MAX5362
Low-Cost, Low-Power 6-Bit DACs with 2-Wire Serial Interface in SOT23 Package MAX5360/MAX5361/MAX5362 Typical Operating Characteristics (continued)
(VDD = 3V (MAX5360), VDD = 5V (MAX5361/MAX5362), TA = +25°C, unless otherwise noted.)
MAX5360 MAX5360 MAX5360 OUTPUT VOLTAGE OUTPUT VOLTAGE OUTPUT SETTLING FROM EXITING SHUTDOWN ENTERING SHUTDOWN 1/4 FS TO 3/4 FS
MAX5360/1/2-19 MAX5360/1/2-20 MAX5360/1/2-21 OUT OUT OUT 500mV/div 500mV/div 0.5V/div SDA SDA SDA 3V/div 3V/div 3V/div 10μs/div 1μs/div 1μs/div
MAX5360 MAX5360 MAX5360 OUTPUT SETTLING FROM OUTPUT SETTLING OUTPUT SETTLING 3/4 FS TO 1/4 FS 1/4LSB STEP-UP 1/4LSB STEP-DOWN
MAX5360/1/2-22 MAX5360/1/2-23 MAX5360/1/2-24 OUT OUT OUT 0.5V/div 20mV/div 20mV/div AC-COUPLED AC-COUPLED SDA SDA SDA 3V/div 3V/div 3V/div 1μs/div 2μs/div 2μs/div 0 x 7F TO 0 x 80 0 x 80 TO 0 x 7F 01111111 TO 10000000 10000000 TO 01111111
Pin Description PIN NAME FUNCTION
1 OUT DAC Voltage Output 2 GND Ground 3 VDD Power-Supply Input 4 SDA Serial Data Input 5 SCL Serial Clock Input
_______________________________________________________________________________________ 7
