Datasheet SN54SC8T151-SEP (Texas Instruments) - 4
| Manufacturer | Texas Instruments |
| Description | Radiation-tolerant eight-line to one-line data selectors/multiplexers with logic-level shifter |
| Pages / Page | 30 / 4 — SN54SC8T151-SEP. www.ti.com. 5 Specifications 5.1 Absolute Maximum … |
SN54SC8T151-SEP. www.ti.com. 5 Specifications 5.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 5.2 ESD Ratings. VALUE
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
SN54SC8T151-SEP
SCASE69 – JANUARY 2025
www.ti.com 5 Specifications 5.1 Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
VCC Supply voltage range –0.5 7 V VI Input voltage range(2) –0.5 7 V VO Voltage range applied to any output in the high-impedance or power-off state(2) –0.5 7 V VO Output voltage range(2) –0.5 VCC + 0.5 V IIK Input clamp current VI < -0.5 V -20 mA IOK Output clamp current VO < -0.5 V or VO > VCC + 0.5 V ±20 mA IO Continuous output current VO = 0 to VCC ±25 mA Continuous output current through VCC or GND ±50 mA Tstg Storage temperature -65 150 °C (1) Operation outside the Absolute Maximum Ratings may cause permanent device damage. Absolute maximum ratings do not imply functional operation of the device at these or any other conditions beyond those listed under Recommended Operating Conditions. If briefly operating outside the Recommended Operating Conditions but within the Absolute Maximum Ratings, the device may not sustain damage, but it may not be fully functional. Operating the device in this manner may affect device reliability, functionality, performance, and shorten the device lifetime. (2) The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
5.2 ESD Ratings VALUE UNIT
Electrostatic Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) ±2000 V(ESD) V discharge Charged-device model (CDM), per ANSI/ESDA/JEDEC JS-002(2) ±1000 (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process.
5.3 Recommended Operating Conditions
Specification Description Condition MIN MAX UNIT
VCC Supply voltage 1.2 5.5 V VI Input voltage 0 5.5 V VO Output voltage 0 VCC V VIH High-level input voltage VCC = 1.2V to 1.3V 0.78 V VCC = 1.65V to 2V 1.1 VCC = 2.25V to 2.75V 1.28 VIH High-level input voltage V VCC = 3V to 3.6V 1.45 VCC = 4.5V to 5.5V 2 VIL Low-Level input voltage VCC = 1.2V to 1.3V 0.18 V VCC = 1.65V to 2V 0.5 VCC = 2.25V to 2.75V 0.65 VIL Low-Level input voltage V VCC = 3V to 3.6V 0.75 VCC = 4.5V to 5.5V 0.85 VCC = 1.6V to 2V ±3 IO Output current VCC = 2.25V to 2.75V ±7 mA VCC = 3.3V to 5.0V ±15 IO Output Current VCC = 4.5V to 5.5V ±25 mA Δt/Δv Input transition rise or fall rate VCC = 1.6V to 5.0V 20 ns/V 4 Submit Document Feedback Copyright © 2025 Texas Instruments Incorporated Product Folder Links: SN54SC8T151-SEP Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information 5.5 Electrical Characteristics 5.6 Switching Characteristics 5.7 Typical Characteristics 6 Parameter Measurement Information 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Balanced CMOS Push-Pull Outputs 7.3.2 SCxT Enhanced Input Voltage 7.3.2.1 Up Translation 7.3.2.2 Down Translation 7.3.3 Clamp Diode Structure 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.1.1 Power Considerations 8.2.1.2 Input Considerations 8.2.1.3 Output Considerations 8.2.2 Detailed Design Procedure 8.2.3 Application Curve 8.3 Power Supply Recommendations 8.4 Layout 8.4.1 Layout Guidelines 8.4.2 Layout Example 9 Device and Documentation Support 9.1 Documentation Support 9.1.1 Related Documentation 9.2 Receiving Notification of Documentation Updates 9.3 Support Resources 9.4 Trademarks 9.5 Electrostatic Discharge Caution 9.6 Glossary 10 Revision History 11 Mechanical, Packaging, and Orderable Information
