Datasheet TPS62933 (Texas Instruments) - 5
| Description | 3.8-V to 30-V, 3-A, 200-kHz to 2.2-MHz, low-IQ synchronous buck converter in SOT-583 package |
| Pages / Page | 51 / 5 — TPS62933, TPS62932. , TPS62933F,. TPS62933P. , TPS62933O. www.ti.com. 8 … |
| File Format / Size | PDF / 4.0 Mb |
TPS62933, TPS62932. , TPS62933F,. TPS62933P. , TPS62933O. www.ti.com. 8 Specifications 8.1 Absolute Maximum Ratings. MIN. MAX. UNIT
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 6
TPS62933, TPS62932 , TPS62933F, TPS62933P , TPS62933O www.ti.com
SLUSEA4D – JUNE 2021 – REVISED AUGUST 2022
Over the recommended operating junction temperature range of –40°C to +150°C , unless otherwise noted(1)
MIN MAX UNIT
VIN –0.3 32 Input voltage EN –0.3 6 FB –0.3 6 SW, DC –0.3 32 SW, transient < 10 ns –3 33 V BST –0.3 SW + 6 Output voltage BST–SW –0.3 6 SS/PG –0.3 6 RT –0.3 6 TJ Operating junction temperature(2) –40 150 °C Tstg Storage temperature –65 150 (1) Operation outside the Absolute Maximum Ratings may cause permanent device damage. Absolute Maximum Ratings do not imply functional operation of the device at these or any other conditions beyond those listed under Recommended Operating Conditions. If used outside the Recommended Operating Conditions but within the Absolute Maximum Ratings, the device may not be fully functional, and this may affect device reliability, functionality, performance, and shorten the device lifetime. (2) Operating at junction temperatures greater than 150°C, although possible, degrades the lifetime of the device.
8.2 ESD Ratings VALUE UNIT
Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all pins(1) ±2000 V(ESD) Electrostatic discharge V Charged device model (CDM), per ANSI/ESDA/JEDEC JS-002, all pins(2) ±500 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
8.3 Recommended Operating Conditions
Over the recommended operating junction temperature range of –40°C to +150°C, unless otherwise noted(1)
MIN NOM MAX UNIT
VIN 3.8 30 EN –0.1 5.5 Input voltage FB –0.1 5.5 PG –0.1 5.5 VOUT 0.8 22 V SW, DC –0.1 30 Output voltage SW, transient < 10 ns –3 32 BST –0.1 SW + 5.5 BST-SW –0.1 5.5 TPS62933, TPS62933x 0 3 Ouput current IOUT A TPS62932 0 2 Temperature Operating junction temperature, TJ –40 150 °C (1) The Recommended Operating Conditions indicate conditions for which the device is intended to be functional, but do not guarantee specific performance limits. For compliant specifications, see the Electrical Characteristics. Copyright © 2022 Texas Instruments Incorporated Submit Document Feedback 5 Product Folder Links: TPS62933 TPS62932 TPS62933F TPS62933P TPS62933O Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Description (continued) 6 Device Comparison Table 7 Pin Configuration and Functions 8 Specifications 8.1 Absolute Maximum Ratings 8.2 ESD Ratings 8.3 Recommended Operating Conditions 8.4 Thermal Information 8.5 Electrical Characteristics 8.6 Typical Characteristics 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.3.1 Fixed Frequency Peak Current Mode 9.3.2 Pulse Frequency Modulation 9.3.3 Voltage Reference 9.3.4 Output Voltage Setting 9.3.5 Switching Frequency Selection 9.3.6 Enable and Adjusting Undervoltage Lockout 9.3.7 External Soft Start and Prebiased Soft Start 9.3.8 Power Good 9.3.9 Minimum On Time, Minimum Off Time, and Frequency Foldback 9.3.10 Frequency Spread Spectrum 9.3.11 Overvoltage Protection 9.3.12 Overcurrent and Undervoltage Protection 9.3.13 Thermal Shutdown 9.4 Device Functional Modes 9.4.1 Modes Overview 9.4.2 Heavy Load Operation 9.4.3 Light Load Operation 9.4.4 Out of Audio Operation 9.4.5 Forced Continuous Conduction Operation 9.4.6 Dropout Operation 9.4.7 Minimum On-Time Operation 9.4.8 Shutdown Mode 10 Application and Implementation 10.1 Application Information 10.2 Typical Application 10.2.1 Design Requirements 10.2.2 Detailed Design Procedure 10.2.2.1 Custom Design With WEBENCH® Tools 10.2.2.2 Output Voltage Resistors Selection 10.2.2.3 Choosing Switching Frequency 10.2.2.4 Soft-Start Capacitor Selection 10.2.2.5 Bootstrap Capacitor Selection 10.2.2.6 Undervoltage Lockout Setpoint 10.2.2.7 Output Inductor Selection 10.2.2.8 Output Capacitor Selection 10.2.2.9 Input Capacitor Selection 10.2.2.10 Feedforward Capacitor CFF Selection 10.2.2.11 Maximum Ambient Temperature 10.2.3 Application Curves 10.3 What to Do and What Not to Do 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Device Support 13.1.1 Third-Party Products Disclaimer 13.1.2 Development Support 13.1.2.1 Custom Design With WEBENCH® Tools 13.2 Receiving Notification of Documentation Updates 13.3 Support Resources 13.4 Trademarks 13.5 Electrostatic Discharge Caution 13.6 Glossary 14 Mechanical, Packaging, and Orderable Information
