Datasheet FS312F-G (Fortune Semiconductor) - 6
ManufacturerFortune Semiconductor
DescriptionThe FS312F-G protection IC for Li-ion/polymer rechargeable one-cell batteries maintains high accurate detections of the abnormal cell activities and the corresponding delay time in order to have protections against the events of over charge, over discharge, and over current.
Pages / Page13 / 6 — 9. Absolute Maximum Ratings (GND=0V, Ta=25°C unless otherwise specified)
File Format / SizePDF / 980 Kb
9 Absolute Maximum Ratings (GND=0V, Ta=25°C unless otherwise specified)
Symbol Rating Unit Input voltage between VCC and GND * VCC GND-0.3 to GND+10 V OC output pin voltage VOC VCC -24 to VCC +0.3 V OD output pin voltage VOD GND-0.3 to VCC +0.3 V FO
Fo P R
r R ro TU
ef pe NE
er rti
en es
ce
O
nl
y Item CS input pin voltage VCS VCC -24 to VCC +0.3 V Operating Temperature Range TOP -40 to +85 °C Storage Temperature Range TST -40 to +125 °C Note: FS312F-G contains a circuit that will protect it from static discharge; but please take special care that no
excessive static electricity or voltage which exceeds the limit of the protection circuit will be applied to it.
