Datasheet SS34AQ (Yangzhou Yangjie)
ManufacturerYangzhou Yangjie
DescriptionSurface Mount Schottky Rectifier
Pages / Page4 / 1 — RoHS. SS32AQ THRU SS34AQ. COMPLIANT. Surface Mount Schottky Rectifier. …
File Format / SizePDF / 230 Kb
RoHS. SS32AQ THRU SS34AQ. COMPLIANT. Surface Mount Schottky Rectifier. Features. Typical Applications. Mechanical Data. Package
Datasheet SS34AQ Yangzhou Yangjie
RoHS SS32AQ THRU SS34AQ   COMPLIANT
Surface Mount Schottky Rectifier Features
● Low profile package ● Ideal for automated placement ● Guardring for overvoltage protection ● Low power losses, high efficiency ● High forward surge capability ● Meets MSL level 1, per J-STD-020, LF maximum peak of 260 °C ● Part no. with suffix “Q” means AEC-Q101 qualified
For use in low voltage high frequency inverters, freewheeling, DC/DC converters, automotive and polarity protection applications.
Mechanical Data
Package
: DO-214AC (SMA) Molding compound meets UL 94 V-0 flammability rating, RoHS-compliant, halogen-free ●
Terminals
: Tin plated leads, solderable per J-STD-002 and JESD22-B102 ●
Polarity:
Cathode line denotes the cathode end ■
Maximum Ratings
(Ta=25℃ Unless otherwise specified)
PARAMETER SYMBOL UNIT SS32AQ SS33AQ SS34AQ
Device marking code SS32A SS33A SS34A Repetitive peak reverse voltage VRRM V 20 30 40 Maximum RMS voltage VRMS V 14 21 28 Maximum DC blocking voltage VDC V 20 30 40 Maximum average forward rectified current at TL (Fig.1) IO A 3.0 Surge(non-repetitive)forward current I @60Hz half-sine wave,1 cycle, T FSM A 80 J=25℃ Voltage rate of change (rated VR) dV/dt V/μs 10000 Storage temperature Tstg ℃ -55 ~+150 Junction temperature TJ ℃ -55 ~+150 ■
Electrical Characteristics
PARAMETER SYMBOL TEST CONDITIONS TYP MAX UNIT
TJ=25℃ 0.48 0.5 Instantaneous forward voltage VF IF=3A V TJ=125℃ 0.41 0.45 TJ=25℃ 15 100 μA Reverse current IR Rated VR TJ=125℃ - 30 mA Typical junction capacitance CJ VR=4V,f=1MHz 150 - pF 1 / 4 S-S4279 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com Rev.1.1,15-Sep-22
