Datasheet SS34AQ (Yangzhou Yangjie) - 2
| Manufacturer | Yangzhou Yangjie |
| Description | Surface Mount Schottky Rectifier |
| Pages / Page | 4 / 2 — SS32AQ THRU SS34AQ . Thermal Characteristics. PARAMETER. SYMBOL. UNIT. … |
| File Format / Size | PDF / 230 Kb |
SS32AQ THRU SS34AQ . Thermal Characteristics. PARAMETER. SYMBOL. UNIT. SS32AQ. SS33AQ. SS34AQ. Characteristics. Ordering Information
SS32AQ THRU SS34AQ
(Ta=25℃ Unless otherwise specified)
PARAMETER SYMBOL UNIT SS32AQ SS33AQ SS34AQ
R θJ-A 551) Thermal Resistance ℃/W RθJ-L 171) Note (1) Thermal resistance from junction to ambient and from junction to lead mounted on P.C.B. with 0.2" x 0.2" (5.0 mm x 5.0 mm) copper pad areas ■
Characteristics
(Typical) Fig.1:Forward Current Derating Curve Fig.2:Maximum Non-Repetitive Peak Forward Surge Current 3.5 80 8.3ms Single Half Sin-Wave ent(A) 3.0 urr 60 2.5 urrent(A) ectified C 2.0 40 ard R 1.5 ard Surge C Forw ge Forw 1.0 20 a er Peak Av 0.5 0.0 0 25 50 75 100 125 150 1 10 100 Lead Temperature( ) ℃ Number of Cycles at 60 Hz Fig.3:Typical Instantaneous Forward Characteristics Fig.4:Typical Reverse Leakage Characteristics 10 100 urrent (A) 10 ent(mA) 1 urr ard C 1 erse C ev R 0.1 0.1 tantaneous Forw T Ins J=-40℃ 0.01 T =25℃ J tantaneous TJ=25℃ T =100℃ J T Ins T =100℃ J J=125℃ T =125℃ J TJ=150℃ 0. TJ=150℃ 01 0.001 0.0 0.2 0.4 0.6 0.8 0 20 40 60 80 100 120 Instantaneous Forward Voltage(V) Percent of Rated Peak Reverse Voltage(%) ■
(Example)
PREFERED PACKAGE MINIMUM OUTER CARTON DELIVERY UNIT WEIGHT(g) P/N CODE PACKAGE(pcs) QUANTITY(pcs) MODE
SS32AQ-SS34AQ F2 Approximate 0.067 7500 120000 13” reel 2 / 4 S-S4279 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com Rev.1.1,15-Sep-22
