Datasheet CT4022 (Allegro) - 4
ManufacturerAllegro
DescriptionIsolated, 500kHz TMR Current Sensor in 1 mΩ SOIC-8 Package
Pages / Page5 / 4 — XtremeSense™ TMR Current Sensor. CT4022 and CT4032. with High dV/dt …
File Format / SizePDF / 775 Kb
XtremeSense™ TMR Current Sensor. CT4022 and CT4032. with High dV/dt Immunity and Common-Mode Field Rejection
XtremeSense™ TMR Current Sensor CT4022 and CT4032 with High dV/dt Immunity and Common-Mode Field Rejection
XtremeSense™ TMR Current Sensor CT4022 and CT4032 with High dV/dt Immunity and Common-Mode Field Rejection For Reference Only
– N
ot for
T
ooling
U
se
(Reference MS-013AA) Dimensions in millimeters Dimensions exclusive of mold flash, gate burrs, and dambar protrusions Exact case and lead configuration at supplier discretion within limits shown 10.30 ±0.20 8° 0° 16 0.33 0.20 0.92 D 7.50 ±0.10 10.30 ±0.33 A 1.40 REF 1 2 1.27 0.69 D 0.40 Branded Face 0.25 BSC SEATING PLANE 16× C SEA SE TING GAUGE PLANE ATING 0.10 C PLANE CT4032 1.27 BSC 2.65 MAX 0.51 0.31 0.30 0.10 CT4032 Lot Number 1 A Terminal #1 mark area B Branding scale and appearance at supplier discretion B Standard Branding Reference View C Reference land pattern layout (reference IPC7351 Line 1: Part Number SOIC127P600X175-8M); all pads a minimum of 0.20 mm from all Line 2: First 8 characters of Assembly Lot Number adjacent pads; adjust as necessary to meet application process requirements and PCB layout tolerances 1.27 1.27 16 0.65 16 0.65 2.25 1.65 9.50 9.75 1 2 1 2 C PCB Layout Reference View High-Isolation PCB Layout Reference View
Figure 3: SOICW-16 Package Drawing and Dimensions
4 Allegro MicroSystems 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com
