Datasheet BZX79 (NXP) - 4
ManufacturerNXP
DescriptionVoltage regulator diodes
Pages / Page12 / 4 — Table 1. B/C2V4. B/C24. WORKING VOLTAGE. DIFFERENTIAL RESISTANCE. TEMP. …
File Format / SizePDF / 78 Kb
Table 1. B/C2V4. B/C24. WORKING VOLTAGE. DIFFERENTIAL RESISTANCE. TEMP. COEFF. DIODE CAP. NON-REPETITIVE PEAK. VZ (V). rdif (. SZ (mV/K)
Table 1 B/C2V4 B/C24 WORKING VOLTAGE DIFFERENTIAL RESISTANCE TEMP COEFF DIODE CAP NON-REPETITIVE PEAK VZ (V) rdif ( SZ (mV/K)
This text is here in white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader.This text is here in _white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader.This text is here inThis text is here in white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader. white to force landscape pages to be ... 2002 Philips Semiconductors
Table 1
Per type, BZX79-
B/C2V4
to BZX79-
B/C24
V Tj = 25 °C unless otherwise specified. oltage regulator diodes Feb 27
WORKING VOLTAGE DIFFERENTIAL RESISTANCE TEMP. COEFF. DIODE CAP. NON-REPETITIVE PEAK VZ (V) rdif (
Ω
) SZ (mV/K) Cd (pF) REVERSE CURRENT BZX79- at IZtest = 5 mA at IZtest = 5 mA at f = 1 MHz; IZSM (A) Bxxx
(see Figs 5 and 6)
VR = 0 V at tp = 100
µ
s; Tamb = 25
C Tol. approx. Cxxx Tol.
2% (B)
at I 5% (C) Ztest = 1 mA at IZtest = 5 mA MIN. MAX. MIN. MAX. TYP. MAX. TYP. MAX. MIN. TYP. MAX. MAX. MAX.
2V4 2.35 2.45 2.2 2.6 275 600 70 100 −3.5 −1.6 0 450 6.0 2V7 2.65 2.75 2.5 2.9 300 600 75 100 −3.5 −2.0 0 450 6.0 3V0 2.94 3.06 2.8 3.2 325 600 80 95 −3.5 −2.1 0 450 6.0 3V3 3.23 3.37 3.1 3.5 350 600 85 95 −3.5 −2.4 0 450 6.0 3V6 3.53 3.67 3.4 3.8 375 600 85 90 −3.5 −2.4 0 450 6.0 3V9 3.82 3.98 3.7 4.1 400 600 85 90 −3.5 −2.5 0 450 6.0 4V3 4.21 4.39 4.0 4.6 410 600 80 90 −3.5 −2.5 0 450 6.0 4V7 4.61 4.79 4.4 5.0 425 500 50 80 −3.5 −1.4 0.2 300 6.0 4 5V1 5.00 5.20 4.8 5.4 400 480 40 60 −2.7 −0.8 1.2 300 6.0 5V6 5.49 5.71 5.2 6.0 80 400 15 40 −2.0 1.2 2.5 300 6.0 6V2 6.08 6.32 5.8 6.6 40 150 6 10 0.4 2.3 3.7 200 6.0 6V8 6.66 6.94 6.4 7.2 30 80 6 15 1.2 3.0 4.5 200 6.0 7V5 7.35 7.65 7.0 7.9 30 80 6 15 2.5 4.0 5.3 150 4.0 8V2 8.04 8.36 7.7 8.7 40 80 6 15 3.2 4.6 6.2 150 4.0 9V1 8.92 9.28 8.5 9.6 40 100 6 15 3.8 5.5 7.0 150 3.0 10 9.80 10.20 9.4 10.6 50 150 8 20 4.5 6.4 8.0 90 3.0 11 10.80 11.20 10.4 11.6 50 150 10 20 5.4 7.4 9.0 85 2.5 12 11.80 12.20 11.4 12.7 50 150 10 25 6.0 8.4 10.0 85 2.5 13 12.70 13.30 12.4 14.1 50 170 10 30 7.0 9.4 11.0 80 2.5 BZX79 ser 15 14.70 15.30 13.8 15.6 50 200 10 30 9.2 11.4 13.0 75 2.0 Product specification 16 15.70 16.30 15.3 17.1 50 200 10 40 10.4 12.4 14.0 75 1.5 18 17.60 18.40 16.8 19.1 50 225 10 45 12.4 14.4 16.0 70 1.5 20 19.60 20.40 18.8 21.2 60 225 15 55 12.3 15.6 18.0 60 1.5 22 21.60 22.40 20.8 23.3 60 250 20 55 14.1 17.6 20.0 60 1.25 ies 24 23.50 24.50 22.8 25.6 60 250 25 70 15.9 19.6 22.0 55 1.25 Document Outline FEATURES APPLICATIONS DESCRIPTION LIMITING VALUES ELECTRICAL CHARACTERISTICS THERMAL CHARACTERISTICS GRAPHICAL DATA PACKAGE OUTLINE SOD27 DATA SHEET STATUS DEFINITIONS DISCLAIMERS
