Datasheet BZX79 (NXP) - 5
ManufacturerNXP
DescriptionVoltage regulator diodes
Pages / Page12 / 5 — Table 2. B/C27. B/C75. WORKING VOLTAGE. DIFFERENTIAL RESISTANCE. TEMP. …
File Format / SizePDF / 78 Kb
Table 2. B/C27. B/C75. WORKING VOLTAGE. DIFFERENTIAL RESISTANCE. TEMP. COEFF. DIODE CAP. NON-REPETITIVE PEAK. VZ (V). rdif (. SZ (mV/K)
Table 2 B/C27 B/C75 WORKING VOLTAGE DIFFERENTIAL RESISTANCE TEMP COEFF DIODE CAP NON-REPETITIVE PEAK VZ (V) rdif ( SZ (mV/K)
This text is here in white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader.This text is here in _white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader.This text is here inThis text is here in white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader. white to force landscape pages to be ... 2002 Philips Semiconductors
Table 2
Per type, BZX79-
B/C27
to BZX79-
B/C75
V Tj = 25 °C unless otherwise specified. oltage regulator diodes Feb 27
WORKING VOLTAGE DIFFERENTIAL RESISTANCE TEMP. COEFF. DIODE CAP. NON-REPETITIVE PEAK VZ (V) rdif (
Ω
) SZ (mV/K) Cd (pF) REVERSE CURRENT BZX79- at IZtest = 2 mA at IZtest = 2 mA at f = 1 MHz; IZSM (A) Bxxx
(see Figs 5 and 6)
VR = 0 V at tp = 100
µ
s; Tamb = 25
C Tol. approx. Cxxx Tol.
2% (B)
at I 5% (C) Ztest = 0.5 mA at IZtest = 2 mA MIN. MAX. MIN. MAX. TYP. MAX. TYP. MAX. MIN. TYP. MAX. MAX. MAX.
27 26.50 27.50 25.1 28.9 65 300 25 80 18.0 22.7 25.3 50 1.0 30 29.40 30.60 28.0 32.0 70 300 30 80 20.6 25.7 29.4 50 1.0 33 32.30 33.70 31.0 35.0 75 325 35 80 23.3 28.7 33.4 45 0.9 36 35.30 36.70 34.0 38.0 80 350 35 90 26.0 31.8 37.4 45 0.8 39 38.20 39.80 37.0 41.0 80 350 40 130 28.7 34.8 41.2 45 0.7 43 42.10 43.90 40.0 46.0 85 375 45 150 31.4 38.8 46.6 40 0.6 47 46.10 47.90 44.0 50.0 85 375 50 170 35.0 42.9 51.8 40 0.5 51 50.00 52.00 48.0 54.0 90 400 60 180 38.6 46.9 57.2 40 0.4 5 56 54.90 57.10 52.0 60.0 100 425 70 200 42.2 52.0 63.8 40 0.3 62 60.80 63.20 58.0 66.0 120 450 80 215 58.8 64.4 71.6 35 0.3 68 66.60 69.40 64.0 72.0 150 475 90 240 65.6 71.7 79.8 35 0.25 75 73.50 76.50 70.0 79.0 170 500 95 255 73.4 80.2 88.6 35 0.2 BZX79 ser Product specification ies Document Outline FEATURES APPLICATIONS DESCRIPTION LIMITING VALUES ELECTRICAL CHARACTERISTICS THERMAL CHARACTERISTICS GRAPHICAL DATA PACKAGE OUTLINE SOD27 DATA SHEET STATUS DEFINITIONS DISCLAIMERS
