Datasheet B_S-1WR3 (Mornsun) - 3
ManufacturerMornsun
Description1W isolated DC-DC converter
Pages / Page6 / 3 — DC/DC Converter B_S-1WR3 Series. General Specifications. Item. Operating …
DC/DC Converter B_S-1WR3 Series. General Specifications. Item. Operating Conditions. Min. Typ. Max. Unit
DC/DC Converter B_S-1WR3 Series General Specifications Item Operating Conditions Min Typ Max Unit
DC/DC Converter B_S-1WR3 Series General Specifications Item Operating Conditions Min. Typ. Max. Unit Input-output electric strength test for 1 minute with a leakage current of 1mA max. 1500 -- -- Isolation VDC 5V input, input-output electric strength test for 1 second with a leakage current of 1mA max. 3000 -- -- Insulation Resistance Input-output resistance at 500VDC 1000 -- -- M
Ω
Isolation Capacitance Input-output capacitance at 100kHz/0.1V -- 20 -- pF 3.3V input Derating when operating temperature Operating Temperature
100
, (see Fig. 2) -40 -- 105 Other input Derating when operating temperature
85
, (see Fig. 2)
Storage Temperature -55 -- 125 Case Temperature Rise Ta=25
-- 25 -- Pin Soldering Resistance Temperature Soldering spot is 1.5mm away from case for 10 seconds -- -- 300 5V input -- -- 95 Storage Humidity Non-condensing %RH Other output 5 -- 95 Vibration 3.3V/12V/15V/24V input 10-150Hz, 5G, 0.75mm. along X, Y and Z 3.3V input, ful load, nominal input voltage -- 220 -- Switching Frequency 5V input, ful load, nominal input voltage -- 270 -- kHz 12V/15V/24V input, ful load, nominal input voltage -- 260 -- MTBF MIL-HDBK-217F @ 25
3500 -- -- k hours Mechanical Specifications Case Material Black plastic; flame-retardant and heat-resistant (UL94 V-0) Dimensions 11.60 x 6.00 x 10.16 mm Weight 1.3g (Typ.) Cooling Method Free air convection Electromagnetic Compatibility (EMC) CE CISPR32/EN55032 CLASS B Emissions RE CISPR32/EN55032 CLASS B Immunity ESD IEC/EN61000-4-2 Air ±8kV, Contact ±6kV perf. Criteria B Note: Refer to Fig.4 for recommended circuit test. Typical Characteristic Curves 3.3VDC output 3.3/5VDC input other output 2024.09.10-A/6 Page 3 of 6 MORNSUN Guangzhou Science & Technology Co., Ltd. reserves the copyright and right of final interpretation
