Datasheet VIA2000SD (Vishay) - 2
ManufacturerVishay
DescriptionHigh Reliability Reinforced Isolated Amplifier in SOP-8 (300 mil) Package
Pages / Page12 / 2 — VIA2000SD. ABSOLUTE MAXIMUM RATINGS. PARAMETER. SYMBOL. VALUE. UNIT. …
File Format / SizePDF / 197 Kb
VIA2000SD. ABSOLUTE MAXIMUM RATINGS. PARAMETER. SYMBOL. VALUE. UNIT. Notes. FUNCTIONAL BLOCK DIAGRAM. RECOMMENDED OPERATING CONDITIONS
VIA2000SD ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT Notes FUNCTIONAL BLOCK DIAGRAM RECOMMENDED OPERATING CONDITIONS
VIA2000SD
(Tamb = 25 °C, unless otherwise specified)
Power supply voltage VDD1, VDD2 -0.3 to 6.5 V VIN GND1-6 to VDD1+0.5 V Input voltage SHTDN GND1-0.5 to VDD1+0.5 V Output voltage OUTP, OUTN GND2-0.5 to VDD2+0.5 V Output current per output pin IO -10 to +10 mA Operating temperature Tamb -40 to +125 °C Junction temperature Tj -40 to +150 °C Storage temperature Tstg -55 to +150 °C HBM (1) ± 2000 V Electrostatic discharge CDM (2) ± 1000 V
Notes
(1) Human body model (HBM), per AEC-Q100-002-RevD (2) Charged device model (CDM), per AEC-Q100-011-RevB
VDD1 VDD2 VDD1 detection Reference Reference OUTP Low pass V Buffer Σ-Δ modulator IN TX RX filter OUTN Isolation Barrier SHTDN RX TX Oscillator GND1 GND2 Fig. 1 - VIA2000SD Block Diagram
PARAMETER SYMBOL MIN. TYP. MAX. UNIT
Side 1 power supply VDD1 3.0 5.0 5.5 V Side 2 power supply VDD2 3.0 3.3 5.5 V Differential input voltage V before clipping output clipping - 2.56 - V VIA2000SD Linear differential input full V scale voltage FSR 0.02 - 2 V Digital input voltage SHTDN GND1 - VDD1 Operating ambient temperature Tamb -40 - +125 °C Rev. 1.1, 02-Apr-2025
2
Document Number: 80902 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
