Datasheet MAX44260 (Analog Devices) - 5
| Description | 1.8V, 15MHz Low-Offset, Low-Power, Rail-to-Rail I/O Op Amps |
| Pages / Page | 14 / 5 — Typical Operating Characteristics |
| File Format / Size | PDF / 1.0 Mb |
MAX44259/MAX44260/ 1.8V, 15MHz Low-Offset, MAX44261/MAX44263 Low-Power, Rail-to-Rail I/O Op Amps
(VDD = 3.3V, VSS = 0V, VIN+ = VIN- = VDD/2, RL = 10kI to VDD/2, VCAL = VSHDN = VDD, TA = -40NC to +125NC. Typical values are at TA = +25NC, unless otherwise noted. All devices are 100% production tested at TA = +25NC. Temperature limits are guaranteed by design.) OUTPUT-VOLTAGE LOW INPUT BIAS CURRENT vs. OUTPUT SINK CURRENT INPUT OFFSET DRIFT HISTOGRAM vs. COMMON-MODE VOLTAGE (VOL - VEE, VCC = 1.8V) 18 100 200 16 80 180 MAX44260 toc04 14 60 MAX44260 toc05 160 MAX44260 toc06 40 12 T 140 A = +25°C 20 120 10 TA = +25°C 0 100 8 -20 80 6 TA = +125°C -40 TA = -40°C TA = +85°C 60 PERCENT OCCURRENCE (%) INPUT BIAS CURRENT (pA) 4 -60 OUTPUT-VOLTAGE LOW (mV) 40 TA = -40°C T 2 A = +125°C -80 20 0 -100 0 -2 -1.5 -1 -0.5 0 0.50 1.00 -0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 0.1 1 10 100 -1.8 -1.3 -0.8 -0.3 0.25 0.75 1.25 COMMON-MODE VOLTAGE (V) OUTPUT SINK CURRENT (mA) INPUT OFFSET DRIFT (µV/°C) OUTPUT-VOLTAGE LOW OUTPUT-VOLTAGE LOW OUTPUT-VOLTAGE HIGH vs. OUTPUT SINK CURRENT vs. OUTPUT SINK CURRENT vs. OUTPUT SOURCE CURRENT (VOL - VEE, VCC = 3.3V) (VOL - VEE, VCC = 5V) (VCC - VOH, VCC = 1.8V) 200 200 200 180 180 180 160 MAX44260 toc07 160 MAX44260 toc08 160 MAX44260 toc09 140 TA = +25°C 140 140 TA = +25°C TA = +25°C 120 120 120 100 100 100 80 80 80 TA = +125°C TA = +125°C TA = +125°C 60 60 60 OUTPUT-VOLTAGE LOW (mV) OUTPUT-VOLTAGE LOW (mV) 40 40 OUTPUT-VOLTAGE HIGH (mV) 40 TA = -40°C 20 TA = -40°C 20 TA = -40°C 20 0 0 0 0.1 1 10 100 0.1 1 10 100 0.1 1 10 100 OUTPUT SINK CURRENT (mA) OUTPUT SINK CURRENT (mA) OUTPUT SOURCE CURRENT (mA) www.maximintegrated.com Maxim Integrated │ 5
