Datasheet MAX44260 (Analog Devices) - 6
Description1.8V, 15MHz Low-Offset, Low-Power, Rail-to-Rail I/O Op Amps
Pages / Page14 / 6 — Typical Operating Characteristics
MAX44259/MAX44260/ 1.8V, 15MHz Low-Offset, MAX44261/MAX44263 Low-Power, Rail-to-Rail I/O Op Amps
(VDD = 3.3V, VSS = 0V, VIN+ = VIN- = VDD/2, RL = 10kI to VDD/2, VCAL = VSHDN = VDD, TA = -40NC to +125NC. Typical values are at TA = +25NC, unless otherwise noted. All devices are 100% production tested at TA = +25NC. Temperature limits are guaranteed by design.) OUTPUT-VOLTAGE HIGH OUTPUT-VOLTAGE HIGH vs. OUTPUT SOURCE CURRENT vs. OUTPUT SOURCE CURRENT (VCC - VOH, VCC = 3.3V) (VCC - VOH, VCC = 5V) SUPPLY CURRENT vs. SUPPLY VOLTAGE 200 200 900 180 180 850 160 MAX44260 toc10 160 MAX44260 toc11 MAX44260 toc12 TA = +25°C 140 T 140 A = +25°C TA = +25°C 800 120 120 TA = +125°C 100 100 750 80 80 TA = +125°C TA = +125°C 700 60 TA = -40°C 60 SUPPLY CURRENT (µA) TA = -40°C OUTPUT-VOLTAGE HIGH (mV) OUTPUT-VOLTAGE HIGH (mV) 40 40 TA = -40°C 650 20 20 0 0 600 0.1 1 10 100 0.1 1 10 100 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 OUTPUT SOURCE CURRENT (mA) OUTPUT SOURCE CURRENT (mA) SUPPLY VOLTAGE (V) SHUTDOWN SUPPLY CURRENT vs. SUPPLY VOLTAGE OPEN-LOOP GAIN COMMON-MODE REJECTION RATIO (VSHDN = VEE) vs. FREQUENCY vs. FREQUENCY 1.0 120 0 0.9 T 100 -20 0.8 A = +125°C MAX44260 toc13 MAX44260 toc14 MAX44260 toc15 0.7 80 -40 0.6 0.5 -60 T 60 A = -40°C 0.4 CMRR (dB) 40 -80 0.3 TA = +25°C OPEN-LOOP GAIN (dB) SHUTDOWN SUPPLY CURRENT (µA) 0.2 20 -100 0.1 0 0 -120 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1 10 100 1k 10k 100k 1M 10M 100M 10 100 1k 10k 100k 1M 10M 100M SUPPLY VOLTAGE (V) FREQUENCY (Hz) FREQUENCY (Hz) POWER-SUPPLY REJECTION RATIO DC CMRR AND PSRR INPUT VOLTAGE-NOISE DENSITY vs. FREQUENCY vs. TEMPERATURE vs. FREQUENCY 0 -90 500 ) 450 -20 √Hz MAX44260 toc16 -92 DC CMRR MAX44260 toc17 400 MAX44260 toc18 -40 350 -94 300 -60 250 PSRR (dB) -96 200 -80 REJECTION RATIO (dB) 150 -98 100 -100 DC PSRR INPUT VOLTAGE-NOISE DENSITY (nV/ 50 -120 -100 0 10 100 1k 10k 100k 1M 10M 100M -50 -25 0 25 50 75 100 125 10 100 1k 10k 100k 1M 10M FREQUENCY (Hz) TEMPERATURE (°C) FREQUENCY (Hz) www.maximintegrated.com Maxim Integrated │ 6
