Datasheet MAX44260 (Analog Devices) - 7
| Description | 1.8V, 15MHz Low-Offset, Low-Power, Rail-to-Rail I/O Op Amps |
| Pages / Page | 14 / 7 — Typical Operating Characteristics |
| File Format / Size | PDF / 1.0 Mb |
MAX44259/MAX44260/ 1.8V, 15MHz Low-Offset, MAX44261/MAX44263 Low-Power, Rail-to-Rail I/O Op Amps
(VDD = 3.3V, VSS = 0V, VIN+ = VIN- = VDD/2, RL = 10kI to VDD/2, VCAL = VSHDN = VDD, TA = -40NC to +125NC. Typical values are at TA = +25NC, unless otherwise noted. All devices are 100% production tested at TA = +25NC. Temperature limits are guaranteed by design.) TOTAL HARMONIC DISTORTION INPUT CURRENT-NOISE DENSITY vs. INPUT AMPLITUDE 0.1Hz TO 10Hz OUTPUT-VOLTAGE NOISE vs. FREQUENCY (f = 10kHz, VCC = 5.5V, AV = 1V/V) MAX44260 toc19 5.0 120 4.5 √Hz) 115 4.0 MAX44260 toc20 MAX44260 toc21 110 3.5 3.0 105 2µV/div 2.5 100 THD (dB) 2.0 95 1.5 90 1.0 INPUT-CURRENT NOISE DENSITY (fA/ 0.5 85 0 80 4s/div 10 100 1000 10k 100k 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 FREQUENCY (Hz) INPUT AMPLITUDE (V) TOTAL HARMONIC DISTORTION vs. FREQUENCY (VIN = 2VP-P) SMALL-SIGNAL TRANSIENT RESPONSE LARGE-SIGNAL TRANSIENT RESPONSE -80 MAX44260 toc23 MAX44260 toc24 -85 INPUT INPUT MAX44260 toc22 50mV/div 1V/div -90 VCC/2 VCC/2 -95 -100 VCC = 5.5V THD (dB) OUTPUT -105 500mV/div -110 OUTPUT VCC/2 VCC = 3.3V 50mV/div -115 VCC/2 -120 1 10 100 1k 10k 100k 200ns/div 100ns/div FREQUENCY (Hz) www.maximintegrated.com Maxim Integrated │ 7
