Datasheet MAX44260 (Analog Devices) - 8
| Description | 1.8V, 15MHz Low-Offset, Low-Power, Rail-to-Rail I/O Op Amps |
| Pages / Page | 14 / 8 — Typical Operating Characteristics |
| File Format / Size | PDF / 1.0 Mb |
MAX44259/MAX44260/ 1.8V, 15MHz Low-Offset, MAX44261/MAX44263 Low-Power, Rail-to-Rail I/O Op Amps
(VDD = 3.3V, VSS = 0V, VIN+ = VIN- = VDD/2, RL = 10kI to VDD/2, VCAL = VSHDN = VDD, TA = -40NC to +125NC. Typical values are at TA = +25NC, unless otherwise noted. All devices are 100% production tested at TA = +25NC. Temperature limits are guaranteed by design.) PERCENT OVERSHOOT STABILITY vs. CAPACITIVE LOAD STABILITY vs. CAPACITIVE vs. LOAD RESISTANCE (VIN = 100mVP-P) AND ISOLATION RESISTANCE AND RESISTIVE LOAD 20 30 100k 28 18 26 16 ) MAX44260 toc25 24 MAX44260 toc26 10k MAX44260 toc27 (I 22 14 ) 20 (I 12 18 1k UNSTABLE 16 10 14 8 12 STABLE 100 OVERSHOOT (%) STABLE 10 6 RESISTIVE LOAD ISOLATION RESISTANCE 8 4 6 UNSTABLE 10 4 2 2 0 0 1 100 1k 10k 100k 0 500 1000 1500 2000 2500 3000 3500 4000 100 1k 10k 100k LOAD RESISTANCE (I) CAPACITIVE LOAD (pF) CAPACITIVE LOAD (pF) POWER-UP TIME TURN-ON TIME FROM SHUTDOWN MAX44260 toc28 MAX44260 toc29 VCC SHDN 2V/div 2V/div GND VSS OUTPUT OUTPUT 500mV/div 500mV/div VSS GND 4ms/div 10µs/div www.maximintegrated.com Maxim Integrated │ 8
