Datasheet MAX44260 (Analog Devices) - 9
| Description | 1.8V, 15MHz Low-Offset, Low-Power, Rail-to-Rail I/O Op Amps |
| Pages / Page | 14 / 9 — Pin Configurations. SOT23. Thin. DFN. (Ultra-Thin LGA). Pin Description |
| File Format / Size | PDF / 1.0 Mb |
MAX44259/MAX44260/ 1.8V, 15MHz Low-Offset, MAX44261/MAX44263 Low-Power, Rail-to-Rail I/O Op Amps
Pin Configurations
TOP VIEW NOT TO SCALE + + + OUT 1 5 VDD IN+ 1 MAX44260 6 VDD IN+ 1 MAX44261 6 VDD VSS 2 VSS 2 5 SHDN VSS 2 5 CAL IN- 3 4 OUT IN- 3 4 OUT IN+ 3 4 IN- MAX44259 SC70 SC70
SOT23
TOP VIEW MAX44263 VDD SHDN OUT + OUTA 1 8 V 6 5 4 DD INA- 2 7 OUTB MAX44260 INA+ 3 6 INB- VSS 4 5 INB+ 1 2 3 + SC70 IN+ VSS IN-
Thin
µ
DFN (Ultra-Thin LGA) Pin Description
PIN NAME FUNCTION MAX44259 MAX44260 MAX44261 MAX44263 3 1 1 — IN+ Positive Input Negative Power Supply. Bypass with a 0.1 2 2 2 4 V FF capacitor to SS ground. 4 3 3 — IN- Negative Input 1 4 4 — OUT Output — — 5 — CAL Active-Low Calibrate Input — 5 — — SHDN Active-Low Shutdown Positive Power Supply. Bypass with a 0.1 5 6 6 8 V FF capacitor to DD ground. — — — 1 OUTA Channel A Output — — — 2 INA- Channel A Negative Input — — — 3 INA+ Channel A Positive Input — — — 5 INB+ Channel B Positive Input — — — 6 INB- Channel B Negative Input — — — 7 OUTB Channel B Output www.maximintegrated.com Maxim Integrated │ 9
