Datasheet IGB03N120H2 (Infineon) - 2
ManufacturerInfineon
DescriptionHighSpeed 2-Technology for 1200V in PG-TO263-3-2 Package
Pages / Page12 / 2 — Thermal Resistance. Parameter Symbol. Conditions. Max. Value. Unit. …
Thermal Resistance. Parameter Symbol. Conditions. Max. Value. Unit. Characteristic. Electrical Characteristic,. min. Typ. max
Thermal Resistance Parameter Symbol Conditions Max Value Unit Characteristic Electrical Characteristic, min Typ max
IGB03N120H2
Thermal Resistance Parameter Symbol Conditions Max. Value Unit Characteristic
IGBT thermal resistance, RthJC 2.0 K/W junction – case Thermal resistance, RthJA 40 junction – ambient1)
at Tj = 25 °C, unless otherwise specified
Value Parameter Symbol Conditions Unit min. Typ. max. Static Characteristic
Collector-emitter breakdown voltage V(BR)CES VGE=0V, IC=300µA 1200 - - V Collector-emitter saturation voltage VCE(sat) VGE = 15V, IC=3A Tj=25°C - 2.2 2.8 T - 2.5 - j = 150 ° C V G E = 1 0 V, I C =3A , Tj=25°C - 2.4 - Gate-emitter threshold voltage VGE(th) IC=90µA,VCE=VGE 2.1 3 3.9 Zero gate voltage collector current ICES VCE=1200V,VGE=0V µA Tj=25°C - - 20 T - - 80 j = 150 ° C Gate-emitter leakage current IGES VCE=0V,VGE=20V - - 100 nA Transconductance gfs VCE=20V, IC=3A - 2 - S
Dynamic Characteristic
Input capacitance Ciss VCE=25V, - 205 - pF Output capacitance Coss VGE=0V, - 24 - Reverse transfer capacitance C f=1MHz r s s - 7 - Gate charge QGate VCC=960V, IC=3A - 22 - nC VGE=15V Internal emitter inductance LE - 7 - nH measured 5mm (0.197 in.) from case 1) Device on 50mm*50mm*1.5mm epoxy PCB FR4 with 6cm2 (one layer, 70µm thick) copper area for collector connection. PCB is vertical without blown air. Power Semiconductors 2 Rev. 2.4 Oct. 07
