Datasheet TB9M001FTG (Toshiba) - 2
| Manufacturer | Toshiba |
| Description | Automotive IC for DC motors with integrated microcontroller |
| Pages / Page | 38 / 2 — Preliminary. 4. Functions |
| File Format / Size | PDF / 4.9 Mb |
Preliminary
TB9M001FTG
4. Functions
Arm® Cortex®-M0 Processor - SerialWireDebugSupport - 32ch Interrupt Controller - 1 cycle multiplier - Up to 40MHz clock frequency 12KBytes ROM (BootLoader, Flash API) (incECCSEC/DED) 192KBytes Code Flash (incECCSEC/DED) 16KBytes Data Flash (incECCSEC/DED) 32-bit Compare timers (DTIMER) 28-bit Capture timer (8 inputs, 6 measurement) WATCHDOG Power saving modes (CPU Sleep, Standby, CWU) 4 Legacy PWM Generator 14 General-purpose I/O Ports (GPIO) 10-bit A/D Converter (GADC) with 13 analog inputs (ADIN0-7、SWIN0-4) + internal temperature, VB, VCC 4 Low Side Drivers (LSD0-3) High Side Drivers (HSD0, HSD1) 9 High Voltage Input (SWIN0-4 + HPIN0-3) LDOs (LDO5V, LDO15V) Power On Reset (POR5V, PORL) 2 on-chip OSCs (IOSCH, IOSCL) External OSC PLL LIN ISO17987/SAEJ2602 transceiver + controller 2 full duplex serial interfaces (UART1, UART2), UART1 with LIN support SPI-I/F Thermal Shutdown (TSD) Package P-VQFN48-0707-0.50 Single power supply from 6.0V to 18V Temperature Range Tj: -40 up to 150°C Green package (RoHS compliant) AEC-Q100 grade 1 Qualified © 2 025 2 2025-05-30 Toshiba Electronic Devices & Storage Corporation Rev. 1.0 Document Outline 1. Description 2. Applications 3. Features 4. Functions 5. Block Diagram 6. Pin Assignments 7. Pin Description 8. I/O Equivalent Circuits 9. Functional Description 9.1. CPU 9.1.1. Overview 9.1.2. Arm® Cortex®-M0 Processor 9.1.3. Configurable Options 9.1.4. External Signals 9.1.5. Module Organization 9.2. LINPHY 9.3. LINCNT/UART1 9.4. SPI 9.4.1. External Signals 9.5. GPIO 9.6. 10bit Analog Digital Converter (GADC) 9.7. Low Side Drivers (LSD) 9.8. High Side Drivers (HSD) 9.9. High Voltage Inputs (HVIF) 9.10. Memory Map 10. Electrical Characteristics 10.1. Absolute Maximum Ratings 10.2. Operating Ranges 10.3. Overall Electrical Characteristics 10.4. 5-V/1.5-V Regulator (LDO5V/LDO15V) 10.5. Switch and Hall Sensor IC Inputs(High Voltage Inputs) 10.6. Oscillator 10.7. Reset Generator and Standby Time 10.8. Data Flash 10.9. Program Flash 10.10. LIN 10.11. 12-V High-Side Driver (HSD_VB) 10.12. 5-V High-Side Driver (HSD_VCC) 10.13. Low-Side Drivers 10.14. 10-Bit AD 10.15. DC characteristics 10.16. SPI 10.17. UART 11. Application Circuit Example 12. Package Information 12.1. Package Dimensions 12.2. Marking 13. IC Usage Considerations 13.1. Notes on Handling of ICs 13.2. Points to Remember on Handling of ICs RESTRICTIONS ON PRODUCT USE
