Datasheet TB9M001FTG (Toshiba) - 5
| Manufacturer | Toshiba |
| Description | Automotive IC for DC motors with integrated microcontroller |
| Pages / Page | 38 / 5 — Preliminary. 7. Pin Description. Table 7.1 Pin Description. Pin. Pin … |
| File Format / Size | PDF / 4.9 Mb |
Preliminary. 7. Pin Description. Table 7.1 Pin Description. Pin. Pin Name. I/O. Description. No
Preliminary
TB9M001FTG
7. Pin Description Table 7.1 Pin Description Pin Pin Name I/O Description No.
1 HVIA0/SWIN0 I High-voltage logic input/switch input 2 HVIA1/SWIN1 I High-voltage logic input/switch input 3 LIN I/O LIN communication pin 4 LINGND - LIN ground 5 HVIA2/SWIN2 I High-voltage logic input/switch input 6 HVIA3/SWIN3 I High-voltage logic input/switch input 7 HVIA4/SWIN4 I High-voltage logic input/switch input 8 GNDP - Ground (for LSD) 9 OUTL0 O Low-side driver output 10 OUTL1 O Low-side driver output 11 OUTL2 O Low-side driver output 12 OUTL3 O Low-side driver output 13 HVIB0/HPIN0 I High-voltage logic input/hall sensor input 14 HVIB1/HPIN1 I High-voltage logic input/hall sensor input 15 HVIB2/HPIN2 I High-voltage logic input/hall sensor input 16 HVIB3/HPIN3 I High-voltage logic input/hall sensor input 17 TEST I Test mode select 18 ADIN3/TSEN I ADC input/temperature monitor 19 GPIO_4/ADIN4 I/O General-purpose I/O port 20 GPIO_5/ADIN5 I/O General-purpose I/O port 21 GPIO_6/CSN/ADIN6/UART_Rxd/PWM_x I/O General-purpose I/O port 22 GPIO_7/SDO/ADIN7/UART_Txd/PWM_x I/O General-purpose I/O port 23 GPIO_9/SDI/UART_Txd I/O General-purpose I/O port 24 GPIO_8/SCLK/UART_Rxd I/O General-purpose I/O port 25 GPIO_0/PWM_x I/O General-purpose I/O port 26 GPIO_1/PWM_x/CSN I/O General-purpose I/O port 27 GPIO_2/PWM_x/UART_Rxd I/O General-purpose I/O port 28 GPIO_3/PWM_x/UART_Txd I/O General-purpose I/O port 29 GPIO_12/SWDIO/FDL-RX/SDI I/O General-purpose I/O port 30 GPIO_13/SWCLK/FDL-TX/CSN I/O General-purpose I/O port 31 GPIO_10/UART_Rxd/IGIN0/SDI I/O General-purpose I/O port 32 GPIO_11/UART_Txd/IGIN1/SDO I/O General-purpose I/O port 33 XIN I External oscil ator connection 34 XOUT O External oscil ator connection 35 MD0 I Mode selects 36 MD1 I Mode selects 37 VDD - 1.5-volt regulator output 38 GND - Ground 39 RSTn I/O Reset I/O 40 ADIN1 I ADC input 41 ADIN2 I ADC input 42 OUTH1(VCC) O High-side driver output (VCC) 43 VCC - 5-volt regulator output 44 VAREF I ADC reference voltage input 45 GNDA - Ground 46 ADIN0 I ADC input 47 VB - Battery input 48 OUTH0(VB) O High-side driver output (VCC) - EP - Exposed pad to be connected to GND - Corner pin - Corner pin to be connected to GND © 2 025 5 2025-05-30 Toshiba Electronic Devices & Storage Corporation Rev. 1.0 Document Outline 1. Description 2. Applications 3. Features 4. Functions 5. Block Diagram 6. Pin Assignments 7. Pin Description 8. I/O Equivalent Circuits 9. Functional Description 9.1. CPU 9.1.1. Overview 9.1.2. Arm® Cortex®-M0 Processor 9.1.3. Configurable Options 9.1.4. External Signals 9.1.5. Module Organization 9.2. LINPHY 9.3. LINCNT/UART1 9.4. SPI 9.4.1. External Signals 9.5. GPIO 9.6. 10bit Analog Digital Converter (GADC) 9.7. Low Side Drivers (LSD) 9.8. High Side Drivers (HSD) 9.9. High Voltage Inputs (HVIF) 9.10. Memory Map 10. Electrical Characteristics 10.1. Absolute Maximum Ratings 10.2. Operating Ranges 10.3. Overall Electrical Characteristics 10.4. 5-V/1.5-V Regulator (LDO5V/LDO15V) 10.5. Switch and Hall Sensor IC Inputs(High Voltage Inputs) 10.6. Oscillator 10.7. Reset Generator and Standby Time 10.8. Data Flash 10.9. Program Flash 10.10. LIN 10.11. 12-V High-Side Driver (HSD_VB) 10.12. 5-V High-Side Driver (HSD_VCC) 10.13. Low-Side Drivers 10.14. 10-Bit AD 10.15. DC characteristics 10.16. SPI 10.17. UART 11. Application Circuit Example 12. Package Information 12.1. Package Dimensions 12.2. Marking 13. IC Usage Considerations 13.1. Notes on Handling of ICs 13.2. Points to Remember on Handling of ICs RESTRICTIONS ON PRODUCT USE
