Datasheet LT3041 (Analog Devices) - 9
Description20 V, 1 A, Ultra-Low Noise, Ultra-High PSRR Linear Regulator with VIOC Control
Pages / Page36 / 9 — LT3041. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 4. SET Pin Current …
LT3041. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 4. SET Pin Current vs. Temperature
LT3041 TYPICAL PERFORMANCE CHARACTERISTICS Figure 4 SET Pin Current vs Temperature
Data Sheet
Figure 4. SET Pin Current vs. Temperature Figure 7. Offset Voltage (VOS) Distribution Figure 5. ISET Distribution Figure 8. SET Pin Current vs. Input Voltage Figure 6. Offset Voltage (VOUT – VSET) vs. Temperature Figure 9. Offset Voltage (VOUT – VSET) vs. Input Voltage analog.com Rev. 0 | 9 of 36
Document Outline Features Applications Typical Application General Description Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Output Voltage Output Sensing and Stability Stability and Output Capacitance High Vibration Environments Stability and Input Capacitance PSRR and Input Capacitance Filtering High-Frequency Spikes Output Noise SET Pin (Bypass) Capacitance: Noise, PSRR, Transient Response, and Soft-Start Fast Startup EN/UV Programmable Power Good Externally Programmable Current Limit Output Overshoot Recovery Direct Paralleling for Higher Current PCB Layout Considerations High-Efficiency Linear Regulator: Voltage Input-to-Output Control (VIOC) Typical VIOC Application Thermal Considerations Calculating Junction Temperature Overload Recovery Protection Features Typical Applications Related Products Outline Dimensions Ordering Guide Evaluation Boards
