Datasheet LT3074 (Analog Devices)
| Description | 5.5V, 3A Ultralow Noise, High PSRR, 45mV Dropout Linear Regulator with PMBus |
| Pages / Page | 62 / 1 — Data Sheet. LT3074. FEATURES. GENERAL DESCRIPTION. APPLICATIONS. … |
| File Format / Size | PDF / 2.1 Mb |
Data Sheet. LT3074. FEATURES. GENERAL DESCRIPTION. APPLICATIONS. SIMPLIFIED APPLICATION DIAGRAM. 2.2µF. VOUT(NOMINAL) = 1V
Data Sheet LT3074
FEATURES GENERAL DESCRIPTION
Ultralow RMS Noise: 1.2µVRMS (10Hz to 100kHz) The LT3074 is a low voltage, ultralow noise, and ultrafast Ultralow Spot Noise: 3.5nV/√Hz at 10kHz transient response linear regulator with a PMBus serial Ultralow 1/f Noise: 7µVP-P (0.1Hz to 10Hz) interface. The device supplies up to 3A with a typical High PSRR at High Frequency: 52dB at 1MHz dropout voltage of 45mV. A 4.7µF reference bypass Ultrafast Transient Response capacitor decreases output voltage noise to 1.2μVRMS. Dropout Voltage: 45mV Typical The wide bandwidth and high PSRR permit the use of 100µA Reference Current: ±0.5% Initial Accuracy small ceramic capacitors, saving bulk capacitance and cost. The LT3074 is supported by the LTPowerPlay Precision Current Monitor: ±3% Accuracy at 3A software development tool with a graphical user PMBus Capability Includes: interface (GUI). VOUT, IOUT, VIN, VBIAS, and Temperature Reporting V The LT3074 sources a 100µA precision reference current OUT Margining I to the LT3074’s SETRES pin. Placing a resistor from this OUT Overcurrent and Undercurrent Warn Limits V SETRES pin to GND sets the output voltage. The OUT, VIN, and VBIAS Undervoltage and Overvoltage Warn Limits LT3074’s unity-gain operation provides virtually constant output noise, PSRR, bandwidth and load Overtemperature Warn Limit regulation, independent of the programmed output Stable with Ceramic Output Capacitors (10μF voltage. Additionally, the LT3074 incorporates a unique Minimum) tracking feature (VIOC) to control the upstream Parallel Multiple Devices for Higher Current switching regulator to maintain a constant voltage VIOC Pin to Control Upstream Switching Converter across the LT3074, and hence minimize power 22-Lead (3mm × 4mm) LQFN Package dissipation.
The PMBus control allows to set the output current limit RF Power Supplies: PLLs, VCOs, Mixers, LNAs, PAs from 1A to 6.4A in discrete steps of 0.05A. The PMBus Telemetry feature provides information regarding the High Speed/High Precision Data Converters output voltage and current, input voltage, bias voltage Low Noise Instrumentation and die temperature. The LT3074 features a CLKDIS pin Post-Regulator for Switching Supplies to control the internal clock. Pulling this pin to BIAS FPGA and DSP Power Supplies disables the internal clocks to put LT3074 in the “quiet Medical Applications mode”. The LT3074 is available in a compact 22 lead (3mm × 4mm) LQFN package (laminate package with QFN footprint).
SIMPLIFIED APPLICATION DIAGRAM 2.2µF VOUT(NOMINAL) = 1V 2.375V TO 5.5V V 261kΩ 69.8kΩ IN = 1.3V VBIAS ≥ VOUT + 1.2V V VBIAS = 3.3V IN V V BIAS 10µF OUT + 0.1V TO 5.5V 10kΩ 51kΩ BIAS BIASAF IN ASEL LT3074 VOUT COUT = 10µF 10kΩ 10kΩ 0.47µF BIASDF AC-COUPLED MPWR PG 20mV/DIV V OUT OUT POWER GOOD 1.2V EN 10mA TO 3A SENSE VIOC IOUT = 300mA TO 3A CLKDIS 4.7µF 22µF 3A/µs SLEW RATE R SETCAP s E u L L SDA B M O 12kΩ R SCL SETRES I P OUT T O N ALERT 383kΩ 2A/DIV T O C DGND AGND PGFB IMON 147kΩ
001
5µs/DIV
002
Figure 1. Simplified Application Diagram Figure 2. Transient Response
Rev.0 DOCUMENT FEEDBACK
TECHNICAL SUPPORT
One Analog Wa y, Wilmington, MA 01887 -2356, U.S.A. Tel: 781.329.47 00 ©2024 Analog Devices, Inc. Al l rights rese rve d. Document Outline Features Applications General Description Simplified Application Diagram Revision History Specifications Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) ESD Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Functional Diagrams Applications Information Output Voltage Output Sensing Stability and Output Capacitance High Vibration Environments Stability and Input Capacitance PSRR and Input Capacitance Filtering High Frequency Spikes Output Noise SETCAP Pin Capacitance: Noise, PSRR, Transient Response, and Soft-Start Fast Start Output Voltage Margining BIAS/BIASAF/BIASDF Pin Requirements BIAS Undervoltage Lockout EN/UV Function (Turning the Part ON and OFF) Power Good Indicator Programmable Power Good Current Monitor and Programmable Current Limit Output Overshoot Recovery and Active Discharge Direct Paralleling for Higher Output Current PCB Layout Considerations High Efficiency Linear Regulator – Input-to-Output Voltage Control Thermal Considerations Calculating Junction Temperature Protection Features Serial Bus Addressing Telemetry Readback Fault Reporting and the ALERT pin Bus Timeout TTIMEOUT TLOW:SEXT TLOW:MEXT PMBus Command Details PAGE OPERATION ON_OFF_CONFIG CLEAR_FAULTS WRITE_PROTECT CAPABILITY VOUT_MODE VOUT_OV_WARN_LIMIT VOUT_UV_WARN_LIMIT IOUT_OC_FAULT_LIMIT IOUT_OC_FAULT_RESPONSE OT_WARN_LIMIT VIN_OV_WARN_LIMIT VIN_UV_WARN_LIMIT STATUS_BYTE STATUS_WORD STATUS_VOUT STATUS_IOUT STATUS_INPUT STATUS_TEMPERATURE STATUS_CML STATUS_MFR_SPECIFIC READ_VIN READ_VOUT READ_IOUT READ_TEMPERATURE_1 PMBUS_REVISION IC_DEVICE_ID IC_DEVICE_REV MFR_MARGIN MFR_READ_VBIAS MFR_BIAS_OV_WARN_LIMIT MFR_BIAS_UV_WARN_LIMIT MFR_IOUT_MIN_WARN_LIMIT MFR_SPECIAL_ID MFR_DEFAULT_CONFIG MFR_RAIL_ADDRESS MFR_RESET Typical Application Circuits Outline Dimensions Ordering Guide Evaluation Boards Related Parts
