Datasheet LT4422 (Analog Devices)
| Description | 28V, 4A Ideal Diode |
| Pages / Page | 18 / 1 — Data Sheet. LT4422. FEATURES. GENERAL DESCRIPTION. APPLICATIONS. … |
| File Format / Size | PDF / 709 Kb |
Data Sheet. LT4422. FEATURES. GENERAL DESCRIPTION. APPLICATIONS. SIMPLIFIED APPLICATION DIAGRAM. TO LOAD. OUT. USB PD 3.0. PRIMARY
Data Sheet LT4422
28V, 4A Ideal Diode
FEATURES GENERAL DESCRIPTION
Internal 50mΩ Power Path The LT®4422 is an ideal 1.9V to 28V diode with integrated Wide Operating Voltage Range: 1.9V to 28V P-channel MOSFET. When enabled, 15mV forward Reverse Current Protection voltage regulation minimizes power dissipation while Low 10µA Quiescent Current increasing operating headroom and efficiency Fast 3µs Response to Load Steps compared to a Schottky diode. Low 500nA Off State Current The LT4422 easily ORs power supplies together to Smooth Switchover in Diode-OR Applications increase system reliability and prevent reverse 10-Lead (3mm x 2mm x 0.75mm) LDFN Package conduction. A non-enabled LT4422 blocks up to 28V at the output while exhibiting less than 1μA (typical)
leakage current, providing orders of magnitude improvement over typical Schottky diodes, which leads Schottky Diode Replacement to extended battery life. Battery and Wall Adapter Diode ORing Backup Battery Diode ORing Fast OUT to IN reverse bias detection minimizes reverse Industrial and Consumer Hand-Held Applications current, preventing undesired charging of input batteries. The open-drain STATUS output pulls low when the LT4422 is in shutdown or reverse bias. All registered trademarks and trademarks are the property of their respective owners.
SIMPLIFIED APPLICATION DIAGRAM LT4422 TO LOAD IN OUT USB PD 3.0 PRIMARY POWER SOURCE C1 5V TO 20V 1µF SHDN STATUS N/C GND LT4422 IN OUT BACK-UP Li-Ion CELL 3.6V R1 4.7kΩ D1 SHDN GND STATUS
001
Figure 1. USB PD 3.0 and Back-Up Battery Supply Figure 2. LT4422 I-V CURVE
Rev. 0
DOCUMENT FEEDBACK TECHNICAL SUPPORT
One Analog Wa y, Wilmington, MA 01887 -2356, U.S.A. Tel: 781.329.47 00 ©2024 Analog Devices, Inc. Al l rights rese rve d. Document Outline Features Applications General Description Simplified Application Diagram TABLE OF CONTENTS Revision History Specifications Absolute Maximum Ratings Pin Configurations and Function Descriptions Typical Performance Characteristics Block Diagram Theory of Operation Applications Information USB PD 3.0 and Back-Up Battery Supply Automatic Power Path Control 5V Power Ride-Through High-Voltage Diode-OR Layout and Thermal Considerations Typical Application High-Load Current Application Reverse Input Voltage Protection Related Parts Outline Dimensions Ordering Guide
