Datasheet LT4422 (Analog Devices) - 3
Description28V, 4A Ideal Diode
Pages / Page18 / 3 — Data Sheet. LT4422. SPECIFICATIONS Table 1. Electrical Characteristics. …
File Format / SizePDF / 709 Kb
Data Sheet. LT4422. SPECIFICATIONS Table 1. Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS/COMMENTS. MIN. TYP. MAX. UNITS
Data Sheet LT4422 SPECIFICATIONS Table 1 Electrical Characteristics PARAMETER SYMBOL CONDITIONS/COMMENTS MIN TYP MAX UNITS
Data Sheet LT4422 SPECIFICATIONS Table 1. Electrical Characteristics
(Specifications are at TA = 25°C, IN = SHDN = 8.4V, unless otherwise noted.)
Operating Voltage Range VIN -40°C ≤ TJ ≤ 125°C 1.9 28 V I Quiescent Current in OUT = -10mA I Measured -40°C ≤ T Forward Regulation CC J ≤ 125°C -10 -18 µA Through GND Quiescent Current in SHDN = GND I Measured -40°C ≤ T Shutdown SD J ≤ 125°C -0.1 -2 µA Through GND IN = GND, Reverse Leakage Current I OUT = 28V, -40°C ≤ T to IN REV(IN) J ≤ 125°C -0.1 -2 µA SHDN = GND IN = GND, Reverse Leakage Current I OUT = 28V, -40°C ≤ T to OUT REV(OUT) J ≤ 125°C 0.1 4 µA SHDN = GND Forward Regulation V Voltage (IN - OUT) REG IOUT = -10mA -40°C ≤ TJ ≤ 125°C 5 15 25 mV Internal Path On- R Resistance ON IOUT = -2A -40°C ≤ TJ ≤ 125°C 29 50 100 m Step OUT from Reverse Turn-Off Time tREV 8.4V to 8.6V -40°C ≤ TJ ≤ 125°C 15 30 µs STATUS Falling Step I Response Time to Load OUT from t -10mA to -1A, -40°C ≤ T Step FON J ≤ 125°C 3 4 µs COUT = 10µF SHDN Rising Threshold VSRT -40°C ≤ TJ ≤ 125°C 1 1.3 1.6 V SHDN Hysteresis VHYST -40°C ≤ TJ ≤ 125°C -75 -130 -230 mV SHDN Input Current I SHDN SHDN = 28V -40°C ≤ TJ ≤ 125°C 1 2 µA Step SHDN from SHDN Delay to Power t GND to IN -40°C ≤ T Path Enable ON J ≤ 125°C 570 1000 µs STATUS Released Step SHDN from SHDN Delay to Power t IN to GND -40°C ≤ T Path Disable OFF J ≤ 125°C 85 160 µs STATUS Falling STATUS Output Voltage I V STATUS = 1mA, -40°C ≤ T Low OL(STAT) J ≤ 125°C 180 410 mV SHDN = GND STATUS Output High I Leakage OH(STAT) STATUS = 28V -40°C ≤ TJ ≤ 125°C ±5 ±200 nA .
analog.com
Rev. 0 3 of 18 Document Outline Features Applications General Description Simplified Application Diagram TABLE OF CONTENTS Revision History Specifications Absolute Maximum Ratings Pin Configurations and Function Descriptions Typical Performance Characteristics Block Diagram Theory of Operation Applications Information USB PD 3.0 and Back-Up Battery Supply Automatic Power Path Control 5V Power Ride-Through High-Voltage Diode-OR Layout and Thermal Considerations Typical Application High-Load Current Application Reverse Input Voltage Protection Related Parts Outline Dimensions Ordering Guide
