Datasheet Q6008LTH1LED (Littelfuse)
| Manufacturer | Littelfuse |
| Description | Qdrc LED App 600V 8A 33/43V TO220 Iso |
| Pages / Page | 6 / 1 — Teccor® brand Thyristors. Description. Agency Approval. Main Features. … |
| File Format / Size | PDF / 576 Kb |
Teccor® brand Thyristors. Description. Agency Approval. Main Features. Features. Benefits. Schematic Symbol. Additional Information
8 Amp Alternistor Quadrac for LED dimmer applications Q6008LTH1LED Series RoHS
The Quadrac is an internally triggered Triac designed for AC switching and phase control applications. It is a Triac and DIAC in a single package, which saves user expense by eliminating the need for separate Triac and DIAC components. Q6008LTH1LED series is designed to meet low load current characteristics typical in LED lighting applications. By keeping holding current at 6mA maximum, this Quadrac series is characterized and specified to perform best with LED loads. The Q6008LTH1LED series is best suited for LED dimming controls to obtain the lowest levels of light output with a minimum probability of flickering. Q6008LTH1LED series is offered in the industry standard
Agency Approval
TO-220AB package with an isolated mounting tab that makes it best suited for adding an external heat sink. Agency Agency File Number L Package : E71639
Main Features Features Benefits
Symbol Value Unit • As low as 6mA max • Provides full control holding current of light out put at the I 8 A T(RMS) extreme low end of load V / V 600 V conditions. DRM RRM DIAC V 33 to 43 V • UL recognized TO-220AB • 2500V min isolation BO AC package between mounting tab and active terminals • 110°C rated junction • Improves margin of safe
Schematic Symbol
temperature operation with less heat sinking required • di/dt performance of • Enable survivability of typical y LED load MT2 MT1 70A/μs operating characteristics • QUADRAC version • Simplicity of circuit design T includes intergrated DIAC & layout • RoHS compliant
Additional Information Applications
Excellent for AC switching and phase control applications such as lighting and motor speed controls. Typical applications are AC solid-state switches, light dimmers with LED loads, small low current motor in power tools,
Datasheet Resources Samples
and low current motors in home/brown goods appliances. Internally constructed isolated package is offered for ease of heat sinking with highest isolation voltage. © 2016 Littelfuse, Inc. Specifications are subject to change without notice. Revised: 05/02/16
