Datasheet Q6008LTH1LED (Littelfuse) - 6
| Manufacturer | Littelfuse |
| Description | Qdrc LED App 600V 8A 33/43V TO220 Iso |
| Pages / Page | 6 / 6 — Teccor® brand Thyristors. Dimensions — TO-220AB (L-Package) — Isolated … |
| File Format / Size | PDF / 576 Kb |
Teccor® brand Thyristors. Dimensions — TO-220AB (L-Package) — Isolated Mounting Tab. Product Selector. Packing Options
8 Amp Alternistor Quadrac for LED dimmer applications
T MEASURING POINT C Inches Millimeters O 8.13 Dimension E A P .320 Min Max Min Max B A 0.380 0.420 9.65 10.67 C AREA (REF.) 0.17 in2 13.36 B 0.105 0.115 2.67 2.92 D .526 7.01 C 0.230 0.250 5.84 6.35 .276 D 0.590 0.620 14.99 15.75 E 0.142 0.147 3.61 3.73 F F 0.110 0.130 2.79 3.30 R G G 0.540 0.575 13.72 14.61 L H 0.025 0.035 0.64 0.89 H J 0.195 0.205 4.95 5.21 K N K 0.095 0.105 2.41 2.67 J M MT1 MT2 T (Trigger) Note: Maximum torque L 0.060 0.075 1.52 1.91 to be applied to mounting tab is 8 in-lbs. (0.904 Nm). M 0.085 0.095 2.16 2.41 N 0.018 0.024 0.46 0.61 O 0.178 0.188 4.52 4.78 P 0.045 0.060 1.14 1.52 R 0.038 0.048 0.97 1.22
Product Selector
Part Number Type Package Q6008LTH1LED Alternistor Quadrac TO-220L Note: xx = Voltage
Packing Options
Part Number Marking Weight Packing Mode Base Quantity Q6008LTH1LEDTP Q6008LTH1 2.2 g Tube 500 (50 per tube)
Part Numbering System Part Marking System
Q 60 08 L T H1LED TO-220 AB - (L Package)
DEVICE TYPE LED LIGHTING APPLICATION
Q: Quadrac
Q6008LTH1 VOLTAGE RATING TRIAC TYPE YMXXX
60: 600V H1: Low Holding Current Alternistor Quadrac ®
CURRENT RATING Trigger
08: 8A T: Internal Diac (33V – 43V)
PACKAGE TYPE
L: TO-220 (Isolated) Date Code Marking Y:Year Code M: Month Code XXX: Lot Trace Code © 2016 Littelfuse, Inc. Specifications are subject to change without notice. Revised: 05/02/16
