Datasheet AAF5060PBESEEVG (Kingbright)
ManufacturerKingbright
Description5.0mm x 6.0mm Full Color LED Lamp
Pages / Page6 / 1 — 5.0mm x 6.0mm FULL COLOR LED LAMP. ATTENTION. Features. Description. …
File Format / SizePDF / 191 Kb
5.0mm x 6.0mm FULL COLOR LED LAMP. ATTENTION. Features. Description. Package Dimensions. SPEC NO: DSAG5858
Datasheet AAF5060PBESEEVG Kingbright
PRELIMINARY SPEC Part Number: AAF5060PBESEEVGA BLUE
ATTENTION
HYPER ORANGE OBSERVE PRECAUTIONS GREEN FOR HANDLING ELECTROSTATIC DISCHARGE SENSITIVE DEVICES
Features Description
●OUTSTANDING MATERIAL EFFICIENCY. The Blue source color devices are made with InGaN on SiC ●RELIABLE AND RUGGED. Light Emitting Diode. ● The Hyper Orange source color devices are made with WATER CLEAR LENS. DH InGaAlP on GaAs substrate Light Emitting Diode. ●LOW POWER CONSUMPTION. The Green source color devices are made with InGaN on ●ONE BLUE, ONE ORANGE AND ONE GREEN CHIPS IN G-SiC Light Emitting Diode. ONE PACKAGE. Static electricity and surge damage the LEDS. ●CAN PRODUCE ANY COLOR IN VISIBLE SPECTRUM, It is recommended to use a wrist band or anti-electrostatic INCLUDING WHITE LIGHT. glove when handling the LEDs. ●MOISTURE SENSITIVITY LEVEL : LEVEL 4. All devices, equipment and machinery must be electrically ●RoHS COMPLIANT. grounded.
Package Dimensions
Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25(0.01") unless otherwise noted. 3. Lead spacing is measured where the leads emerge from package. 4. Specifications are subject to change without notice.
SPEC NO: DSAG5858 REV NO: V.1 DATE: JUN/22/2006 PAGE: 1 OF 6 APPROVED: J. Lu CHECKED: Allen Liu DRAWN: W.J.ZHU ERP: 1201002375
