Datasheet AS3935 (ScioSense) - 6
ManufacturerScioSense
DescriptionFranklin Lightning Sensor IC with embedded distance estimation algorithm.
Pages / Page44 / 6 — AS3935 −. Pin Number. Pin Name. Pin Type. Description. ams Datasheet. …
AS3935 −. Pin Number. Pin Name. Pin Type. Description. ams Datasheet. Page 5
AS3935 − Pin Number Pin Name Pin Type Description ams Datasheet Page 5
AS3935 −
Pin Assignments
I²C data bus or SPI data input bus Digital I/O with (according to SI setting) 13 I2CD/MOSI pull-up / Digital input In I²C compatible mode a 10k pull up resistor is connected on chip. 14 NC Not connected 15 ADD0 I²C address selection LSB Digital input 16 ADD1 I²C address selection MSB Connect to Ground via the GND plan and Exposed pad Supply pad pin 4
[v1-04] 2016-Jan-13 Document Feedback Document Outline ScioSense_Cover_page AS3935 Data Sheet General Description Key Benefits & Features Applications Block Diagram Pin Assignments Absolute Maximum Ratings Electrical Characteristics Operating Conditions DC/AC Characteristics for Digital Inputs and Outputs Detailed System and Block Specification Typical Operating Characteristics Detailed Description Circuit Operating Modes Power-Down Mode Listening Mode Signal Verification System and Block Specification Register Table Register Table Description and Default Value Serial Peripheral Interface (SPI) SPI Command Structure Writing of Register Data Reading of Data from Addressable Registers (READ Mode) Send Direct Command Byte I²C Guideline for Pull Up Resistors on I2CL and I2CD I²C Byte Write I²C Register Read Direct Command Voltage Regulator Analog Front-End (AFE) and Watchdog Noise Floor Level Measurement and Evaluation Lightning Algorithm Signal Validation Energy Calculation Statistical Distance Estimation Interrupt Management Antenna Tuning Clock Generation Noise Sources to Be Avoided Package Drawings & Markings Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Content Guide
